raja.cedt
hi, i think nobody will give both..generally they give termination resistance at the driver....first you have to see how much swing your RX can detect and how much signal attenuation in channel...sum of these two will give the driver swing.....this swing is the drop across the termination resistance......
Thanks, Rajasekhar.
