Oct 1st, 2026, 11:58pm
jitter in sine and square wave. (Read 14516 times)
dkumar
chennai
Aug 07th, 2009, 1:27pm
i  want to generate the verilogA model for square wave and sine wave with jitter in both.Like same amount of random jitter in both.
I tried looking designer's guide and i did get the square wave generation with jitter. i tried to modify the same for sine wave and was successfully able to do that but the problem is , then i give the same amount of rms jitter value in both sine and square wave and then i plot the eye diagram , i see different pk-pk value of jitter.
i have posted the code here...please let me know if there is any other  way of generating jittery sine and square wave with same amount of random jitter. OR what is the mistake am i doing?
I want to give some jitter RMS value as input and get same amount of random ( and pk-pk) jitter in both square and sine wave.
thanks
CODE:
"SQUARE WAVE WITH JITTER"
// VerilogA for SSS, sqarJ2, veriloga
`include "constants.vams"
`include "disciplines.vams"
module squrJ2 (out);
output out; voltage out;                        // output terminal
parameter real vl=-1; //low output voltage
parameter real vh=1; //high output voltage
parameter real freqT=1 from (0:inf);            // output frequency
parameter real tt=0.01/freqT from (0:inf);     //output transition time
parameter real ttol=1u/freqT from  (0:1/freqT);    // time tolerance
parameter real jitter=0 from [0:0.25/freqT);     // period jitter (produces white accumulating jitter), variance of random normal distribution.
real freq, phase, dT ;
integer n, seed;
analog begin
   @(initial_step) seed = -561;
   // freq to freq2
   freq = freqT;
   // add the phase noise
   freq = freq/(1 + dT*freq);
   // bound the time step to assure no cycles are skipped
   $bound_step(0.6/freqT);
   // phase is the integral of the freq modulo 2p
   phase = 2*`M_PI*idtmod(freq, 0.0, 1.0, -0.5);
   // update jitter twice per period
   // `M_SQRT2=sqrt(K), K=2 jitter updates/period
   @(cross(phase + `M_PI/2, +1, ttol) or cross(phase - `M_PI/2, +1, ttol)) begin
       dT = `M_SQRT2*jitter*$rdist_normal(seed,0, 1);
       n = (phase >= -`M_PI/2) && (phase < `M_PI/2);
   // generate the output
     V(out) <+ transition(n ? vh : vl,330p ,tt);
endmodule\
"SINE WAVE WITH JITTER" ( modified the above one to get this.)
// VerilogA for SSS, sineJ2, veriloga
module sineJ2 (out);
integer  seed;
analog begin
   // freq to freq2
   freq = freqT;
 //    $bound_step(0.6/freqT);
     V(out) <+ 1.2*sin(`M_TWO_PI*freqT*$realtime + phase) ;
     $bound_step(0.06/freqT);
lunren
Asia
Re: jitter in sine and square wave.
Reply #1 - Aug 17th, 2009, 10:32am
http://www.designers-guide.org/Analysis/PLLjitter.pdf
Page 19. Ken recommends that when generating sine wave, the jitter updates once per periode. Maybe this is where the problem is. However, I am also wondering why in sine wave, the jitter updates only once per periode? Can any expert give us some hints?
Lunren
dkumar
chennai
Reply #2 - Aug 17th, 2009, 10:42am
hi,
so i figured out and easy code for fixed frequency oscillator with jitter and i would like to modify this for sinewave as it if for square wave as of now.
`include “disciplines.vams”
module osc (out);
output out; electrical out;
parameter real freq=1 from (0:inf);
parameter real Vlo=–1, Vhi=1;
parameter real tt=0.01/freq from (0:inf);
parameter real jitter=0 from [0:0.1/freq); // period jitter
integer n, seed;
real next, dT;
analog begin
@(initial_step) begin
seed = 286;
next = 0.5/freq + $abstime;
@(timer(next)) begin
n = !n;
dT = jitter∗$rdist_normal(seed,0,1);
next = next + 0.5/freq + 0.707∗dT;
V(out) <+ transition(n ? Vhi : Vlo, 0, tt);
it is on page 18 of this attachment.
prcken
PRC
Reply #3 - Apr 4th, 2016, 10:39am
dkumar wrote on Aug 7th, 2009, 1:27pm:
i  want to generate the verilogA model for........
i found two issues:
1. the output  frequency of the sine wave of the one you are using will be doubled.
it should be
V(out) <+ 1.2*sin(phase) ;
2. the jitter is accumulating with time. the longer time you are simulating, the more peak to peak jitter
how can i get a p2p jitter independent to the simulation time?
thanks
Reply #4 - Apr 4th, 2016, 2:21pm
You should be using $abstime rather than $realtime.
prcken
PRC
Reply #5 - Apr 7th, 2016, 11:10am
Hi Ken,
i tried with $asbtime, as below for comparison
V(Ioutn) <+ sinedc+sineamp*sin(`M_TWO_PI*freqT*$abstime + phase) ;
V(Ioutp) <+ sinedc+sineamp*sin(phase +`M_PI);
Ioutn and Ioutp corresponds to t1 and t2, respectively, in the attached picture
two issues still there, frequency of Ioutn (t1) is doubled, and jitter still accumulates with time, eye diagram folded up to 50ns and 5ns are shown at the left and right in the picture
thanks!
Reply #6 - Apr 8th, 2016, 6:03am
V(Ioutn) <+ sinedc+sineamp*sin(`M_TWO_PI*freqT*$abstime + phase);
I think you are being confused by the term 'phase'. You are probably thinking it is relatively constant, perhaps varying only as a result of the jitter, but that is wrong. In this case phase contains the actual phase of the signal, not its phase offset. So it is going through a full 2π radians every cycle. So, you need to get rid of the `M_TWO_PI*freqT*$abstime. That is redundant and is causing the output to be at twice the frequency you expect.
As far as why the jitter accumulates, that is intended. That is what jitter does in free-running oscillators.
Are you modeling a free-running oscillator?
prcken
PRC
Reply #7 - Apr 9th, 2016, 4:25pm
Hi Ken,
Yea, the phase contains the the freq. instead of the offset freq.
instead of an free-running oscillator, actually i want to produced a PLL output clock with a bounded p2p jitter, not varying with the simulation time.  any advice how to do that?
Thanks!
