Oct 25th, 2024, 4:24pm
Pole at the cascode node (Read 3887 times)
raja.cedt
Aug 24th, 2009, 5:57am
hi,
   can any body explain why pole at the cascode node is not affecting much in the frequency response as well as settling..(i slightly increased cap at the cascode node and checked)?
Rajasekhar.
Mariusz
Re: Pole at the cascode node
Reply #1 - Aug 24th, 2009, 7:25am
It is a low impedance node.
raja.cedt
Reply #2 - Aug 24th, 2009, 8:18pm
hi,
   thats true..but i increased the cap at the that node..still i didn't see much impact...
nobody
Reply #3 - Aug 24th, 2009, 11:02pm
What if you decrease the size of cascoded device, which means you are going to decrease the gm.
vivkr
Reply #4 - Aug 25th, 2009, 4:03am
raja.cedt wrote on Aug 24th, 2009, 5:57am:
hi,
Rajasekhar.
The cascode transistor is an impedance transformer with the source end impedance appearing to be about (1+gm*ro) times smaller than the drain end. That works out to around 30 for older processes and around 10 for the modern ones.
Assuming that the poles due to the cascode device are far far away at the moment (10x > unity gain frequency), then you will see a significant change only if you change the load at the source node significantly, maybe by factor 3x-4x or so.
Vivek
raja.cedt
Reply #5 - Aug 25th, 2009, 9:09pm
hi,
   thanks for your replies......but what i feel there is some zero which is canceling that pole.
Rajasekhar.
subgold
Reply #6 - Aug 26th, 2009, 5:07am
the first nondominant pole of the amp is located at about gds/cgs of the cascode transistor, it definitely has some influence on the frequency response and settling. a zero may come into play if you connect the bulk and source of the cascode transistor together.
