May 3rd, 2024, 11:43pm
Problems assigning parameterizable values in cell (Cadence ADE) (Read 8606 times)
vivkr
Aug 27th, 2009, 7:41am
I created a cell with parameterizable components using pPar. Now I try to assign them values in form of a variable for performing a sweep but the values are reset in the form to a number (the last number used).
Could someone tell me how to get around this? I am using the IC6.1 environment of Cadence ICFB.
Vivek
oermens
Re: Problems assigning parameterizable values in cell (Cadence ADE)
Reply #1 - Aug 27th, 2009, 8:17am
In the Edit CDF Parameter window, there are fields for 'dontSave' and 'editable', did you fill those in mistakenly? I'm not sure what they do so I leave them blank and I have no problem using variables for parameterized devices.
vivkr
Reply #2 - Sep 1st, 2009, 4:54am
I have tried not to fill in anything at all. The only thing I had to do, and which I found strange was to add the parameters manually in the CDF. For some reason, they were not created automatically when generating the symbol from the schematic.
It seemed to work fine and I was able to assign values to the parameters and run simulations, but then suddenly, I was unable too. So I have pParam used inside the cellview but no possibility to assign these while instantiating the parameterizable device. Any clues?
Vivek
Reply #3 - Sep 1st, 2009, 5:59am
Is there any message in the CIW when the values get reset?
Perhaps there is a CDF callback in place which is causing the trouble?
Could you use cdfDump() to dump out the CDF for the problematic cell, to see if it gives any clues? (post it here if you can).
vivkr
Reply #4 - Sep 8th, 2009, 12:08am
Hi Andrew,
I am a bit delayed in my response but I do see a warning message in the CIW which reads like:
*WARNING* Input value must be a number. Setting back to previous value
Please note that the parameters were not automatically included in the CDF when I created the symbol and I had to add them manually using the CDF editor. At that time, I chose the parameter type as "float" and was forced to specify a default value for each parameter.
Vivek
Andrew Beckett wrote on Sep 1st, 2009, 5:59am:
vivkr
Reply #5 - Sep 8th, 2009, 12:16am
I think I need to set the parameter type as "string" in the CDF. Probably that was the issue. Whether it is useful to let the input be parsed as a number or not is unclear to me. For the moment, I am going with the option of not parsing as number and not using any default values for the parameters.
Vivek
Frank Wiedmann
Munich, Germany
Reply #6 - Sep 8th, 2009, 3:08am
You can find the function of the various CDF parameters in chapter 3 of the Component Description Format User Guide (http://sourcelink.cadence.com/docs/files/Release_Info/Docs/cdfuser/cdfuser6.1/ch...).
