Hi Andrew,
I am a bit delayed in my response but I do see a warning message in the CIW which reads like:
*WARNING* Input value must be a number. Setting back to previous value
Please note that the parameters were not automatically included in the CDF when I created the symbol and I had to add them manually using the CDF editor. At that time, I chose the parameter type as "float" and was forced to specify a default value for each parameter.
Vivek
Andrew Beckett wrote on Sep 1st, 2009, 5:59am:Is there any message in the CIW when the values get reset?
Perhaps there is a CDF callback in place which is causing the trouble?
Could you use cdfDump() to dump out the CDF for the problematic cell, to see if it gives any clues? (post it here if you can).
