Sep 28th, 2024, 8:22am
LiIon Battery Characteristics (Read 1884 times)
ic_engr
Sep 03rd, 2009, 10:08am
Hello All,
I am trying to obtain information on LiIon battery characteristics. More specifically:
1. What is the healthy voltage range ?
2. What is the lowest Voltage below which there is effectively no life left in the battery.
3. What can be assumed to be the safe turn on voltage ?
4. Battery impedance relation to charge.
I need this information and more to design a POR for supporting LiIon batteries.
If anyone can provide such information will be greatly appreciated.
ic_engr
Re: LiIon Battery Characteristics
Reply #1 - Sep 5th, 2009, 11:48am
4.3V peak, 2.7V minimum for single cell LI-Ion
the other questions are unique to the particular battery -
time to do some research and read both battery specifications and specs for battery controllers. Look at the INtersil battery product line for chip specs, as a starting point.
