Apr 26th, 2024, 10:18pm
Measure INL/DNL for 16b Sigma-Delta ADC (Read 91 times)
Sep 04th, 2009, 5:56am
Hi Guys,
It seems to be very difficult to measure INL/DNL for high resolution ADC, saying a 16b ΣΔADC. It needs about 40 milliion samples if keeping 95% confidence level for a 16 b ADC. I have a logic analyzer with memory depth of 2M at hand. So I think perhaps that another testing method is prefered. Even I worry about the signal source.
What's your experience in measuring INL/DNL for high resolution ADC? Any comments are appreciated.
Yawei
vivkr
Re: Measure INL/DNL for 16b Sigma-Delta ADC
Reply #1 - Sep 11th, 2009, 1:19am
Hi Yawei,
Depending on the speed and your signal generator, you might want to consider using a ramp signal instead of a sinewave. The number of samples needed drops dramatically since the distribution of the input codes is now uniform instead of bathtub. I remember using such a method for a 14b ADC. Already at 14b level, the number of samples needed was impractically high with a sinewave.
Naturally, there are several disadvantages, the most important being:
(a) difficulty in generating pure ramps.
(b) cannot use a filter to purify the signal.
What you can do in addition is to use a collection of tests to deduce the INL/DNL. In addition to the ramp test, I would recommend the following:
1. A fullpower sinewave test and FFT with coherent sampling (prime number of input cycles) in order to catch as many codes as possible.
2. Running several "localized" INL/DNL histogram tests with sinewave signals approx. FS/32 centered around various critical points in your code range. So for instance, if you had a traditional SAR ADC, you would run a histogram test around 0, +/- FS/2, etc.
3. Transferring data offline to a PC for INL/DNL analysis instead of using a logic analyzer. This may not work if you want to do rapid tests for INL/DNL (I doubt if anyone does that in production for 16b ADCs).
Vivek
Reply #2 - Jan 8th, 2010, 1:59pm
I wopuld approach it a little differently - first, INL-DNL are static tests - automate that with a PC and do it --- DC in --- code out --- type of thinking.
From there, I would runs some linearity tests in a dynamic fasion.
