Jul 22nd, 2024, 12:32am
sigma delta ADC direct demodulation of 1-bit oversampled data (Read 2660 times)
aaron_do
Sep 14th, 2009, 4:22am
suppose i have a sigma-delta ADC with a 1-bit quantizer. Assume I am using this ADC in an FSK receiver. Does anybody know if there has been any work done on directly demodulating the 1-bit oversampled output? In other words, can I avoid the decimation?
thanks,
Aaron
vivkr
Re: sigma delta ADC direct demodulation of 1-bit oversampled data
Reply #1 - Sep 24th, 2009, 2:06am
Hi Aaron,
I don't know of any papers on this specific topic. However, I would be concerned about using such a method since you will basically be sending over the wideband output of the modulator containing high-pass shaped noise. So you firstly need a lot of bandwidth, and secondly the channel nonidealities, specifically the finite bandwidth there and in the receiver will likely cause the shaped noise to fold back into the band. This is not considering other possible headaches that may face such as the backcoupling from your Tx to the delta-sigma modulator.
However, there is no other objection in principle. After all, the bitstream from a delta-sigma modulator is quite "random", similar to real communication channels. As long as you can send and detect with a sufficiently high BER, you should be OK.
Vivek
aaron_do
Reply #2 - Sep 24th, 2009, 5:01am
thanks. I'm trying to find the lowest power method of demodulating a signal coming out of a sigma delta ADC. I'm worried that a decimation filter will require high power consumption and will also leave the signal as a 10-bit signal which may be more complicated to demodulate than a 1-bit signal. Not really sure so i'll probably have to do more reading before I revisit this question...
Aaron
