Sep 16th, 2026, 7:31am
Another difficult fundamental question: about delta sigma modulator (Read 2954 times)
tony_taoyh
Sep 23rd, 2009, 2:45am
Hi, All,
I have another difficult fundamental question for the first order delta sigma modulator.
                                                       ff
x -----(+) ----- {z^-1/(1-z^-1)} ------(+) ------> [8-bit ADC] ------> y
The feedback is a negative one, with 8-bit ideal DAC.
The ADC is also a ideal one.
ff is white noise. x is a DC input.
According to the linear model, the TF is as:
y = x*z^-1 + (ff+qq) * (1-z^-1), where qq is the quantization noise.
According to this model, the ff will also be first-order shaped. Right?
However, from the Matlab behavioral model, ff is NOT shaped.
Is there anybody who can explain this well?
Thanks a lot.
tony_taoyh
Re: Another difficult fundamental question: about delta sigma modulator
Reply #1 - Sep 23rd, 2009, 5:12pm
Some additional information.
In the matlab program, the integrator output will be:
v1(n) = v1(n-1) + 1*(x(n-1) - y(n-1)) + ff(n-1)
It is equivalent to:
v1(n) = v1(n-1) + 1*({x(n-1) + ff(n-1) } - y(n-1))
Assuming the gain of the integrator is 1.
Then, the x + ff can be considered as the input of the modulator.
Both x and ff will NOT be shaped inside the behavioral simulation.
There shoud be some breaking point somewhere, to explain the
contradition between behavioral simulation and linear model.
Thanks.
Berti
Reply #2 - Sep 23rd, 2009, 10:01pm
I think your conclusion is wrong. The output y will contain ff and x. You basically consider the modulator open-loop.
When you close the loop you get y(n) = x(n-1) + (ff(n) - ff(n-1)).
How do you simulate this modulator?
Cheers
