Jul 21st, 2024, 6:18pm
Difficult fundamental question about sampling (Read 5806 times)
tony_taoyh
Sep 22nd, 2009, 1:27am
Hi, All,
The nyquist sampling theorem is well "known".
Also, the aliasing is also "known".
However, what will happen if we are sampling a wideband noise using a lower sampling frequency?
For example, the wideband noise has spectrum from 1 to 1MHz, however, the sampling frequency is only 100kHz, what will be inside the output spectrum? How to calculate the output spectrum with the input spectrum?
Thanks a lot.
MarcoC
Cesena, Italy
Re: Difficult fundamental question about sampling
Reply #1 - Sep 22nd, 2009, 2:00am
Hi Tony,
The noise is folded. In the output spectrum you will see a white spectrum of value around USF*Sin(f) where USF is the under-sampling factor and Sin(f) is the input spectrum.
This is a quick reply but I don't have much time today.
If you wish more understanting take a look to these:
- "Circuit Techniques for reducing the effects of op-amp imperfections: autozeroing, correlated double sampling and chopper stabilization" by G. Temes (this is a paper about CDS and so on but it answers quite well to your question)
- I suggest you also these material:
       http://www.designers-guide.org/Theory/cyclo-paper.pdf
       http://www.cadence.com/rl/Resources/white_papers/tdnoise.pdf
Hope to be helpful.  ;)
Bye
View Profile MarcoC   IP Logged
raja.cedt
Reply #2 - Sep 22nd, 2009, 2:37am
hi,
  answer seems very clear because according to sampling theorem noise will be aliased with sampling frequency rate, and fortunately additional noise is uncorrelated so you will get white spectrum
Rajasekhar.
raja.cedt
Reply #3 - Sep 22nd, 2009, 2:40am
one more thing normally we will keep anti-alias filter to avoid this only
tony_taoyh
Reply #4 - Sep 22nd, 2009, 3:04am
How to calculate them?
For example, before sampling, the noise power density is:
1 v^2/Hz (1~1MHz), what is the power spectrum density after sampling @ 200KHz?
Thanks.
raja.cedt
Reply #5 - Sep 22nd, 2009, 3:19am
hi,
  i feel it is five times because of five times noise folding
Rajasekhar.
MarcoC
Cesena, Italy
Reply #6 - Sep 22nd, 2009, 5:13am
around five times is correct.
1MHz/200KHz
HdrChopper
Reply #7 - Sep 22nd, 2009, 7:23pm
raja.cedt wrote on Sep 22nd, 2009, 2:37am:
hi,
Rajasekhar.
Hi Rajasekhar,
This is about correct. However the bandlimited noise is not totally white: a low pass filtered noise has some degree of correlation, as opposed to an infinite bandwidth noise, which is an idealization we call "white noise" (I´m assuming a flat spectrum).
The aliased noise will then have an about flat spectrum but that does not convert it into white noise, since it will also have a degree of correlation due to the low pass filtering. This correlation will be stronger if after sampling such noise is further filtered.
Concerning the noise aliasing ratio, there is a correction factor that should be considered. For a 1-pole like noise spectrum the equivalent noise BW is 1.57 time the pole frequency. Therefore for the 1MHz case you should consider 1.57MHZ instead (again, assuming 1 pole BW). Therefore the ratio is more like 7.85 times.
Tosei
Keep it simple
raja.cedt
Reply #8 - Sep 22nd, 2009, 9:33pm
hi tosie,
           excellent correction man, but here whose low pass filter action we have to consider here?
Rajasekhar.
