Aug 16th, 2024, 1:15pm
matching questions? (Read 1965 times)
liletian
MD
matching questions?
Sep 15th, 2009, 12:28pm
 Hi Guys
 I had a question on matching. What is the purpose of matching? Well, the following is my calculation.
 Suppose we have a perfect matching for 1mW for 50 ohms.
 Then the voltage at the input points is
 V^2/(2*50)=10^-3,
 V=0.316 V.
Well, let's suppose there is a resistor of 10^5,
then the reflection coefficent is gamma=(10^5-50)/(10^5+50)=1-1*10^-3.
 So the power at the input point is
 (1-gamma^2)*10^-3=2*10^-6.
So the voltage at the input is
 V^2/(2*10^5)=2*10^-6
 V=0.63V
 So in the dismatch case, the voltage is actually twice the input voltage for matching case. I am very confuse about this. Can anyone explain what happened here. In some applications, maximum voltage is better than maximum power, so why do you have to have power match in all the place from antenna to LNA.
 Thank you
aaron_do
Re: matching questions?
Reply #1 - Sep 16th, 2009, 6:04am
Hi liletian,
everybody who has ever designed an LNA has probably asked this question. Including me,
http://www.designers-guide.org/Forum/YaBB.pl?num=1195659245
cheers,
Aaron
