Oct 21st, 2024, 6:56am
Low offset, high speed CMOS comparator (Read 7005 times)
AnalogDE
Sep 17th, 2009, 11:21am
I need to design a high speed comparator with input referred offset < 1.8mV, 3sigma.  What sort of topologies should I be looking at?  Do I need to do offset cancellation?  VDD is 1.8V.
HdrChopper
Re: Low offset, high speed CMOS comparator
Reply #1 - Sep 17th, 2009, 7:18pm
First of all I think I would use a pre amp stage to minimize offset contribution from the decision ckt.
Even in that case the total input referred offset might be larger than what you need to achieve.
So offset cancellation technique like chopping or autozeroing may be necessary (making your preamp diff pair with very large devices to minimize offset might impact your comparator speed).
Autozeroing might be more convenient if your comparator is clocked, unless input referred noise is an issue (aliasing related to autozeroing).
Obviously chopping is the other option.
Tosei
Keep it simple
raja.cedt
Reply #2 - Sep 17th, 2009, 8:55pm
hi,
  first design high speed comparator and don't consider offset and then nullify offset using digital calibration (it is much better than other analog cancellation techniques from tuning point of view)
Rajasekhar.
rajdeep
UK
Reply #3 - Sep 18th, 2009, 8:19am
Hi Rajsekhar,
Can you please suggest any good book or article/paper on digital calibration techniques?
Thanks much!
Rajdeep
raja.cedt
Reply #4 - Sep 19th, 2009, 11:49pm
hi,
   i will check for a good reference for calibration. The main principle is to inject current at the comparator output till offset voltage at the input is zero.
for ref you can see 3rd problem in the following examhttp://bwrc.eecs.berkeley.edu/classes/icdesign/ee240_s09/Exams/final_s08.pdf...
thanks,
Rajasekhar.
HdrChopper
Reply #5 - Sep 20th, 2009, 8:19am
raja.cedt wrote on Sep 17th, 2009, 8:55pm:
hi,
Rajasekhar.
Calibration is certainly another option, but
1) Offset drifts (over temp) will NOT be compensated for, and that might be a problem depending on the application.
2) If done periodically, is then somehow like autozeroing the comparator in a digital rather than in an analog way, and as I pointed out before, might imply some noise performance degradation which might be important in this ckt design.
Tosei
Keep it simple
raja.cedt
Reply #6 - Sep 20th, 2009, 8:40pm
hi Tosei ,
            you are correct about one time cal...but how periodic cal will cause niose problems?
Rajasekhar.
HdrChopper
Reply #7 - Sep 21st, 2009, 6:02pm
Hi Rajasekhar,
That will mainly depend on the bandwith of the noise sources: if your calibration frequency is slower than 2*BWn (noise bandwith) you will start aliasing some noise into the baseband, and therefore degrading the comparator performance.
Tosei
Keep it simple
raja.cedt
Reply #8 - Sep 21st, 2009, 10:53pm
hi tosie,
           thanks for updating, but what i feel you can't avoid white noise folding.
Rajasekhar.
HdrChopper
Reply #9 - Sep 22nd, 2009, 7:14pm
raja.cedt wrote on Sep 21st, 2009, 10:53pm:
hi tosie,
Rajasekhar.
Most probably....but youŽll do if you chop it instead of autozeroing it.
Tosei
Keep it simple
