Jul 16th, 2024, 12:01pm
Measure NF of low-IF mixer (Read 948 times)
aaron_do
Sep 22nd, 2009, 6:57pm
I want to measure the NF of a downconversion mixer with an IF of around 100 kHz. Can anybody reccommend equipment to do this? Currently I am using an ESA spectrum analyzer with built in noise personality (it uses the Y-factor method), but the analyzer is not designed to be used below 10 MHz (although it will output data). So i'm worried that the measurement results are far off.
Another method I thought of using is the gain method where I don't need a noise source. Is this method considered accurate for my application. The DUT gain is around 30 dB and the RF frequency is 2.4 GHz.
thanks,
Aaron
ACWWong
Oxford, UK
Re: Measure NF of low-IF mixer
Reply #1 - Sep 23rd, 2009, 5:48am
I think more important than the gain is the NF you are expecting. A very low noise figure would be more suspectable to measurement errors using simple C/N NF calculation.
aaron_do
Reply #2 - Sep 23rd, 2009, 8:26am
I expect an NF of around 6 dB. I figured that the main consideration is the output noise versus the noise floor of the spectrum analyzer...
thanks,
Aaron
ACWWong
Oxford, UK
Reply #3 - Sep 23rd, 2009, 8:51am
Yes based on these numbers, it should be fine to use a spectrum analyser and C/N method.
Analyser noise floor is easily de-embedded... e.g. noise floor 6dB below DUT noise contibutes 1dB to the measured noise, 10dB below contibutes 0.4dB etc.
A post amp might help to get the DUT noise above analyser noise floor if its a problem.
