Mayank wrote on Nov 1st, 2009, 10:09pm:Yeah,
i got buddy's point raja...But it would have be helpful if some1 could post an example of ac analysis showing normal behaviour while it's otherwise...And What could possible be the reason that poles & zeros of Bode plots FOR MONOTONIC minimum phase functions shows stablitiy while ckt goes unstable ??
thanx,
mayank.
Hi MAYANK !
1) For example, when you by mistake connects the feedback line to the non-inverting opamp input (that means: positive feedback) the result of the ac analysis looks normal. That is because the program does find an operating point (which you also can calculate by hand, but it is unstable). However, the program does not know that it will be unstable because it does not take care about noise and power switch-on.
As another example, take a non-compensated opamp and use 100% feedback. The opamp in reality will be unstable. But you will see that the result of ac analysis - as far as the magnitude is concerned !! - looks normal. However, the phase will exhibit a rapid increase - as in your case!! This is an indication for instability !
2.) The answer to your second question cannot be given in short here in the forum. Please refer to the complete NYQUIST stability criterion. In this context, you should realize that the stability check in the BODE plot is nothing else than a transfer of the NYQUIST criterion from the complex plane to the simpler BODE plot. And according to NYQUIST the parameter called "phase margin" indicates stability/instability not for all kinds of functions. Description and explanation of this criterion can be found in books on control theory.
