Aug 16th, 2024, 10:02am
Driver's behavior w/t or w/o dead time... (Read 7363 times)
sand_dolphin2
Japan
Oct 01st, 2009, 12:02am
Hi!!
This is the first time to write questions in this forum. Embarrassed
I have one question of Verilog-AMS behavior of bellow case. Huh
Verilog-AMS(DUT)
// P-ch(High Side Gate) + N-ch(Low Side Gate) Driver
logic   HG, LG;
analog begin
   if (~HG)
      V(VSW) <+ 4.5;
   else if (LG)
      V(VSW) <+ 0;
testbench-caseA(correct behavior) Smiley
//testcase a) w/o dead time
   initial begin
       HG = 1'b1;
       LG = 1'b0;
       #100;
       forever begin
            HG = 1'b0;
       #640 HG = 1'b1;
            LG = 1'b1;
       #640 LG = 1'b0;
       //#10;
testbench-caseB(incorrect behavior) Undecided
   initial begin
       HG = 1'b1;
       LG = 1'b0;
       #105;
       forever begin
            HG = 1'b0;
       #630 HG = 1'b1;
       #10  LG = 1'b1;
       #630 LG = 1'b0;
       #10;
plz let me know somebody,  :(
why does driver have incorrect behavior w/t dead time(both gate off:testbench-caseB) ?
How to design driver which have correct behavior even though w/t dead time(testbench-caseB)?
I'll wait some comments from somebody...
ciao  :)
boe
Re: Driver's behavior w/t or w/o dead time...
Reply #1 - Oct 2nd, 2009, 9:07am
sand_dolphin2 wrote on Oct 1st, 2009, 12:02am:
...(testbench-caseB)?
The DUT does not specify an output voltage for LG=0 & HG=1, so the node is hi-Z.
What behavior do you expect for this case?
BOE
sand_dolphin2
Japan
Reply #2 - Oct 4th, 2009, 4:18pm
boe wrote on Oct 2nd, 2009, 9:07am:
BOE
Thanks for your kindly reply. Wink
so, My expect behavior in caseB is hi-Z cuz both gates(HG,LG) are off.
I don't know well about Verilog-AMS behavior,
but i guess in case of other statement which is not defined ,
the node will be not driven(hi-Z). Huh
anyway , even if HG or LG is on, v(VSW) does not have correct valuee..... Why... Cry
plz give some comments to solve this....
I'll wait for your and somebody's kindly reply!! Smiley
ciao Smiley
boe
Reply #3 - Oct 5th, 2009, 8:34am
sand_dolphin2 wrote on Oct 4th, 2009, 4:18pm:
The problem is that the analog solver does not notice some of the digital events because the step size is too large. You need to use edge sensitive code in DUT (switch).
analog
  @(negedge HG) <statement>
Note that <statement> is executed only at falling edge of HG (for rising edge use posedge). However this statement should ensure analog simulator notices events.
Further, I suggest you use a transition filter to smooth out analog transitions.
BOE
sand_dolphin2
Japan
Reply #4 - Oct 5th, 2009, 7:46pm
boe wrote on Oct 5th, 2009, 8:34am:
analog
BOE
Thanks for your reply.
This driver should drive High at ~HG  and Low at LG. and there is no case of both Gates on. and original ams have problem only both off case.
i rebuild to make ams file bellow
analog begin
@(negedge HG or posedge LG)
 begin
   if (~HG)
      V(VSW) <+ 4.5;
   else if (LG)
      V(VSW) <+ 0;
but, this design drive constant value only fall/rise edge timing of HG/LG.
V(VSW)'s results is same error behavior even if testbench-caseA like as testbench-caseB . Cry
Plz give some comments!! help me.... Sad
boe
Reply #5 - Oct 7th, 2009, 8:55am
I'd use code like Code:
analog begin
  @(posedge HG or negedge HG or posedge LG or negedge LG) begin
    if (~HG & ~LG)
	begin  vvsw = Vhigh; res = Ron; end
    else if (HG & LG)
	begin vvsw = Vlow; res = Ron; end
    else if (~HG & LG)
	begin vvsw = Vx; res = Rx; end
    else
	res = Roff;
  V(VSW) <+ transition(vvsw, ...) + transition(res, ...) * I(VSW);
BOE
sand_dolphin2
Japan
Reply #6 - Oct 7th, 2009, 9:52pm
Hi boe!
boe wrote on Oct 7th, 2009, 8:55am:
analog begin
    if (~HG & ~LG)
    else if (HG & LG)
    else if (~HG & LG)
    else
	res = Roff;
BOE
Thank you for your cooperation in always Smiley
In this code,
 real vvsw,res;
 parameter Vhigh = 4.5;
 parameter Vlow = 0.0;
 parameter Vx = -10;
 parameter Ron  = 100m;
 parameter Roff = 10M;
 parameter Rx = 1;//not occur cuz w/t deadtime
a)  V(VSW) <+ transition(vvsw, ...);
   or
     V(VSW) <+ vvsw;
b)  V(VSW) <+ transition(vvsw, ...) + transition(res, ...) * I(VSW);
case a) is having a good behavior(expected)
case b) is not well. this behavior is like as first problem.
I wonder that resister should be modeled both HG and LG...
but your way is good way to keep energy of Kirchhoff's laws.
I want to make this model behave as logical function only,
so i should make this model as case a)
Thank's a lots of your kinds Wink
ciao
See you soon!! bye for now
« Last Edit: Oct 8th, 2009, 1:18am by sand_dolphin2 »
sand_dolphin2
Japan
Reply #7 - Oct 12th, 2009, 4:23pm
Hi boe and somebody !!
In this post of first step
logic HG,LG;
electrical VSW_temp;
analog begin
   if (~HG)            // Polarity Inverted (consistency for transister model)
      V(VSW_temp) <+ 4.5;
   else if (LG)
      V(VSW_temp) <+ 0;
   //V(VSW) <+ V(VSW_temp);//CaseA
   V(VSW) <+ transition(V(VSW_temp),0,trise,tfall);//CaseB
w/t transition function CaseB is running well,but w/o transition function CaseA is not good. Huh
What doese make this differ behavior btw w/t and w/o ?
Should we use transition function to act analog solver by trigger of digital solver ?   Sad
I'll wait for your comments!! Wink
ciao Smiley
boe
Reply #8 - Oct 15th, 2009, 9:34am
sand_dolphin2 wrote on Oct 12th, 2009, 4:23pm:
Steps in a signal (of type electrical) are usually bad for convergence, so using a transition filter (which ensures that the signal V(VSW) is differentiable) improves convergence and simulation speed. I also suggest you use a real variable for VSW_temp: this should simulate faster (electrical signals have a lot of overhead).
Hope this helps.
BOE
[Edit:]PS: If you use a transition filter, you need the resistor term to model HiZ.
sand_dolphin2
Japan
Reply #9 - Oct 15th, 2009, 5:07pm
Hi boe!!
Thank you for your cooperation in always!! Smiley
boe wrote on Oct 15th, 2009, 9:34am:
Hope this helps.
BOE
In this case,
there is no need to add transition "filter",
the reason for using transition function is to solve this first step problem.
So, your suggestion of should use not electrical but real
at the solving first step problem,
w/o transition function V(VSW)<+V(VSW_temp); can't treat real.
the nanosim compiler output error code.
then i treat VSW_temp as electrical.
Why should i use transition function for solving this first step problem?
Plz help me... Embarrassed
See you soon,
ciao Wink
boe
Reply #10 - Oct 16th, 2009, 4:18am
sand_dolphin2 wrote on Oct 15th, 2009, 5:07pm:
In this case,
A voltage step across a capacitance requires a (momentaneous) infinite current spike (Dirac pulse), which usually causes problems with the simulator. Even without capacitance at node VSW, simulator convergence should be better with transition "function" (called "transition filter" in the LRM).
The transition filter helps in two ways: 1. It ensures finite first derivative of the voltage and 2. it provides the simulator with information for step size control (rise/fall time).
Therefore you should use Code:
V(VSW) <+ transition(...);
For efficiency reasons you should use a real variable in your if statement. Because (some) simulators consider every assignment to the variable in the transition filter an event (even if the value does not change), you should put the if statement in an analog event control (@) statement as I suggested in reply #5 (http://www.designers-guide.org/Forum/YaBB.pl?num=1254380528#5)
BOE
[Added:]The other purpose of using an analog event control statement is to ensure that no events are lost (by adding analog time points at transitions).
sand_dolphin2
Japan
Reply #11 - Oct 19th, 2009, 12:50am
boe wrote on Oct 16th, 2009, 4:18am:
BOE
I had solved by your kindly advice.
This should be closed, i think.
 how about anybody?  Sad
 if so,please add message or questions Wink
See you soon BOE!
ciao  :)
