Sep 28th, 2024, 2:25am
Pages: 1 2 3
Very accurate Bandgap reference (Read 5330 times)
manodipan
Oct 14th, 2009, 4:43am
Hi Guys,
I need to design a very accurate bandgap reference....it does not matter if it is voltage or current output...the accuracy with temperature required is  less than 0.1%...it would be great if you guys suggest some material...Thanks..
raja.cedt
Re: Very accurate Bandgap reference
Reply #1 - Oct 14th, 2009, 9:00pm
hi,
   have you tried curvature compensated band gap?
Rajasekhar
Berti
Reply #2 - Oct 14th, 2009, 10:42pm
Does accuracy mean "accuracy over temperature" or "absolute accuracy (e.g. 1.24V) constant over PVT"?
Mayank
Reply #3 - Oct 14th, 2009, 11:40pm
     Normally when you design a Band-Gap(say PTAT), it's variation is kept usually below 10%.
For higher accuracies, Go for a Curvature Compensated (PTAT + CTAT) Config as raja suggested.
Also, if your supply is noisy,
You can also go for cascaded BandGaps. Funda being you first generate a local reference through a BandGap, feed it to LDO,now give the local stabilized reference to the final BandGap.
This can give excellent results in case of noisy supply.
thanx,
Mayank.
raja.cedt
Reply #4 - Oct 14th, 2009, 11:59pm
hi,
    manyak you are correct, but i feel this ldo option is the final due to power consumption before that he we can apply many tricks. First identify which one parameter is contributing more error (supply noise, opamp offset, vbe curvature error )
1.Design high bandwidth op amp with less offset because offset will be amplified through some no (i guess it is around 17 roughly) and op amp input referred noise will come directly to the output. Check how opamp offset is changing with temp.
2. Try to budget  as much as possible VDS across top pmos transistors
3.Opamp dynamic PSRR should be good
please correct me if any thing wrong
Questin @ manodeepan: By the way whats your BG voltage (i mean is it general BG or any sub BG ) and architecture?
Rajasekhar.
RobG
Bozeman, MT
Reply #5 - Oct 15th, 2009, 1:50pm
manodipan wrote on Oct 14th, 2009, 4:43am:
Hi Guys,
This is very challenging. You'll need curvature compensation unless your temp range is tight (say +/- 30C). Bigger issue: you will also need to trim out variations in sheet resistance and bipolar Is and various mismatches. A 20% change in sheet resistance or bipolar IS will cause a 0.4% change at room temp and more at 125C. Opamp offsets can easily add that much and are difficult to trim out without screwing up the temp co, so you will need offset compensation (chopping, etc) or trim at two temperature points. Substrate noise can cause DC shifts on that order. PSSR is a comparatively easy thing to solve using high gain opamp in your circuit. Oh, and changes in packaging stress from plastic packages will cause hysteresis when temp cycling and unpredictable tempco. Don't forget bandgap references voltages change as the circuit ages.
Current reference has all those problems and it is directly proportional to the resistor used to generate the current. I doubt if you can build a current reference to 0.1%.
I guess what I'm saying is that you should relax the spec or find a new boss Wink
vivkr
Reply #6 - Oct 16th, 2009, 2:41am
Mayank wrote on Oct 14th, 2009, 11:40pm:
thanx,
Mayank.
Just a comment. You don't call it a Band-Gap if you are using a PTAT. A bandgap is realized first when you combine a PTAT with a CTAT and you can get decent accuracy there (1%).
Vivek
rajdeep
UK
Reply #7 - Oct 16th, 2009, 3:34am
Ya! 1% accuracy is possible with standard architecture, with additional things like cascoding to achieve better PSRR. The accuracy also depends on the process. For example, I had to migrate a design from 600nm to 180nm CMOS process. Same architecture, some tweaks, but the accuracy was really good.
Thats because this new process of 180nm has better matching, and the tempco of the resistors are also a bit better. Finally, trimming is highly recommended if such accuracy is reqd. But then curvature correction at one trim combination is ok.
So, to make a comment on the main question, I guess use the standard architecture, and have trimming option.
The LDO idea was also nice. In fact something that we follow because that LDO can be used for other purposes also, like supplying some logic portion in other part of the chip. But  just to design a standalone bandgap IP, it depends on your area, power requirement!
Just some comments! You have to design it anyway  :P
cheers!
Rajdeep
Reply #8 - Oct 16th, 2009, 5:26pm
Hmmm... Cascoding and running off of LDO power? Interesting concept but give some thought to the thermal and flicker noise that you get from this device, cascodes are noisy things.
Put some noise on the power supply and model the interference/coupling and see what you got. You may want to just LPF the output of the device down to near DC and let the noise of the environment be averaged out.
RobG
Bozeman, MT
Reply #9 - Oct 16th, 2009, 8:16pm
loose-electron wrote on Oct 16th, 2009, 5:26pm:
Hi Loose-e. I know you know your stuff, but could you please elaborate? I don't understand how using an LDO to provide a power supply for a BG reference will add noise (it should increase power supply rejection), or how a cascode is noisy.
rg
raja.cedt
Reply #10 - Oct 17th, 2009, 5:46am
hi,
   i think what loose-electron want to convey is cascading will give noise problems (like the folk proposed cascading with LDO). But even i didn't understand why cascading will  add more supply noise in fact some time it will reduce like in two stage opamp.
rajasekhar.
vivkr
Reply #11 - Oct 19th, 2009, 12:53am
Hi Jerry,
Why would cascoding add significant noise? Some thoughts from my side:
1. Generally, the contribution of the active load is far more signicant than that of the cascode (by factor gm*ro) to any noise current.
2. Then we come to noise bandwidths. If the cascode has much more of it, then maybe its contribution referred to the input would increase as the load mirror frequency response drops off, but I would say that this is generally not so significant.
3. What could worsen the noise when using cascodes is the fact that you need extra headroom to accomodate these => you need to live with lower Vds on the active load => the active loads are made with larger W/L and have higher gm => you have more noise from the load devices than you could potentially have if you didn't need to sacrifice any headroom for that cascode. This difference can be significant for lower supplies.
Are we on the same page or do you have something else in mind?
Vivek
rajdeep
UK
Reply #12 - Oct 19th, 2009, 5:37am
But then cascodes are there to suppress any such noise, it kind of shields the noise which may be present at its drain end if in saturation.
Liked the higher gm => higher noise analysis though!!
Rajdeep
raja.cedt
Reply #13 - Oct 19th, 2009, 6:56am
hi rajdeeep,
                  could you please explain what is " Liked the higher gm => higher noise analysis though!!"
Rajasekhar.
rajdeep
UK
Reply #14 - Oct 19th, 2009, 7:16am
vivkr wrote...
Quote:
 ... with larger W/L and have higher gm => you have more noise from the load devices...
I liked this analysis. Thats what I wrote!!
cheers!
Rajdeep
Pages: 1 2 3
