Sep 28th, 2024, 12:26am
NEGATIVE  Temperature Coefficient (Read 1448 times)
Mayank
Dec 10th, 2009, 4:33am
     I need a CTAT [Complementary to Absolute Temperature] current for Temperature compensation [ i.e. a Negative temperature coefficient ].
    For Temperature compensation of my Oscillator, I require a CTAT current coefficient α of around -1mA/A/K
    [ α as in the equationIactual = Inom * (1 + α*ΔT)] . Means a 5uA decrease in a 100uA bias current for 50 C change in Temperature.
Any suggestions ??  I doubt that a CTAT Bandgap will provide such high CTAT current coefficient ? Can anyone Help ?
--mayank.
ACWWong
Oxford, UK
Re: NEGATIVE  Temperature Coefficient
Reply #1 - Dec 10th, 2009, 2:29pm
A standard CTAT will do. i.e. using a bjt vbe which is about -1~-2mV/oC, you can use an op-amp to make a current in resistor follow this voltage.
So from say 300K to 350K you'll get about a vbe drop of say 700mV to 600mV (obviously depending on technology and current density etc.), which is much better than the 5% you need.
cheers
aw
