Jul 16th, 2024, 9:32am
Modeling amplifier non-linearity in combination with bandwidth limitation (Read 2328 times)
Visjnoe
Oct 14th, 2009, 11:22am
Dear all,
I'm stuck at trying to model an amplifier's non-linearity in combination with a bandwidth limitation. For the non-linearity, I would use a classical third-order Taylor series approach, while for the bandwidth limitation, I would use a first-order, low-pass s-domain transfer function with a certain cut-off frequency.
My conceptual problem arises when it comes down to ordering these two in the signal flow (block) diagram: first the Taylor series and than the s-domain transfer function or vice versa?
When I put the Taylor series first, the model might generate e.g. a third harmonic with the wanted/correct power, but that third harmonic might subsequently be attenuated by the s-domain (lowpass) function (if it falls beyond the cut-off frequency), lowering its power so it 's not in line anymore with the predicted power by the Taylor series.
If I put the s-domain lowpass function first, it might be so that two tones that are present at the model's input get attenuated first and than pass through the Taylor series...thus not generating e.g. the intermodulation products as predicted by the Taylor series (not the correct power).
Any insights/comments welcome on this modeling problem...
Peter
boe
Re: Modeling amplifier non-linearity in combination with bandwidth limitation
Reply #1 - Oct 16th, 2009, 8:51am
Visjnoe,
Assuming a simple opamp, I'd expect non-linearity is mainly caused by input stage and BW limitation by the loading of that or later stages.
So I write my models as non-linearity first, then low-pass.
Of course, if your non-linearity comes from clamping in the output stage, the inverse applies.
BOE
