ACWWong
as well as modelling everything on chip including the interconnect (which you seem to have fairly well covered), you'll then need the bondwire and package model. the exact model depends on the bonding and package you are using. the package pin then contacts the pcb, so you'll get extra capacitance from that pcb pad as well. to model this you'll need to know the dimensions and layers of the pcb. the 4mm pcb trace can simply be modelled as a microstrip line once you have all the pcb details. given you'll have a scope probe on this output, the parasitic presented by the 4mm pcb trace should be relatively small compared to 10pF. also remember also the scope probe impedance, not just the capacitance.
hope this helps... cheers
aw
