May 21st, 2024, 12:23am
Trouble to startup Colpitts Crystal Oscillator while easy with Pierce (Read 1002 times)
neoflash
Mixed-Signal
Designer
Oct 20th, 2009, 7:01pm
Hi Folks:
I'm coming up with a strange issue with Xtal oscillator. With Colpitts design, the Xtal is hard to compensate and the oscillation will not sustain.
However, the same X-tal model with similar transistor size and current, the pierce version can work pretty well.
I've attached both schematics on and hope you can help me analyze the problem.
Neo
neoflash
Mixed-Signal
Designer
Re: Trouble to startup Colpitts Crystal Oscillator while easy with Pierce
Reply #1 - Oct 20th, 2009, 7:02pm
Pierce version works well and easily start.
neoflash
Mixed-Signal
Designer
Reply #2 - Oct 20th, 2009, 7:51pm
I also tried to make Colpitts current / transistor size 10x larger. However, it still doesn't start up.
