Sep 28th, 2024, 8:23am
pole zero analysis of bandgap voltage reference (Read 2334 times)
yvkrishna
Oct 23rd, 2009, 12:58am
Can someone tell how to estimate the pole zero in the bandgap  circuit (2)shown here. Please point me to any references dealing with stability analysis of bandgap circuits (pole zero estimation)
I dont understand the need/advantage of using the additional resistors r1 and r3 in the fig (2)
In fig (2) can we also take the o/p reference at the other end (above resistor r1)? If so which one is better ?
vamshi
raja.cedt
Re: pole zero analysis of bandgap voltage reference
Reply #1 - Nov 5th, 2009, 6:32am
hi,
 R1 mainly to reduce systemic offset in current mirrors
 R3 is to adjust op amp common mode voltage, please refer this pap '' Design Considerations of Recent Advanced Low-Voltage
Low-Temperature-Coefficient CMOS Bandgap Voltage Reference''
Rajasekhar.
