Jul 22nd, 2024, 6:26pm
About switched capacitor circuits in flash ADC (Read 2859 times)
VINAY RAO
Oct 23rd, 2009, 1:23am
hi,,
    whether the usage of switched capacitor circuits in flash ADC's results sampling  rate to be decreased?? or it increases its performance in related with sampling rate?
raja.cedt
Re: About switched capacitor circuits in flash ADC
Reply #1 - Oct 23rd, 2009, 8:10am
hi,
  could you please explain clearly? i mean where you want to use switch cap..generally preamp before comparator is switch cap based  (mainly for offset cancellation)..so this will give inherent sample and hold rather than putting s/h in front of the ADC. but now days people are using again s/h hold in front of the ADC for several improvements.
Rajasekhar.
Reply #2 - Oct 23rd, 2009, 7:02pm
Vinay:
There are a number of good textbooks out there on the subject. May I suggest getting a few books and doing some research?
Jerry
