Aug 16th, 2024, 1:22am
help on second order effect! (Read 2121 times)
kibby
Oct 23rd, 2009, 8:21am
if the function of mos fet in saturation region is used:
i=1/2*ucw/l*(vgs-vth)^2
which ignore the second order effect;
to analyse the character of gm''(the second derivative of gm) of a simple full differential amplifier,then is the result helpful for design? or it is unreasonable?
why?
thx~
Riad KACED
Swindon, UK
Re: help on second order effect!
Reply #1 - Oct 23rd, 2009, 10:42am
Hi Kibby,
Yes, this is a reasonable approach for hand calculation. This is the way every designer goes calculate the first-step transistors. The second stage is to run a Spice level simulation, using Spectre, Eldo, Hspice ... etc. Simulators using models like BSIM3/BSIM4/PSP DO NOT assume any approximation at all, they give you the 'exact numbers' which are likely to be different from your hand-calculation.
Cheers,
Riad.
Riad KACED
PDK, EDA Support Engineer.
kibby
Reply #2 - Oct 24th, 2009, 4:23am
thank you for your help~
