Apr 29th, 2024, 12:30am
Monte Carlo "sensitivity" analysis, comparator offset (Read 5445 times)
AnalogDE
Oct 26th, 2009, 2:33pm
I am simulating comparator DC offset using Monte Carlo analysis in Eldo.  Is there a way to do a sort of "sensitivity" analysis so that eldo can point me to the devices that contribute the most to the offset ?  That way, I can pinpoint those devices and upsize them to get the most bang for the buck...
Thanks in advance
BackerShu
Re: Monte Carlo "sensitivity" analysis, comparator offset
Reply #1 - Dec 3rd, 2009, 4:20am
I also want to measure the DC offset of a compatator.
A method mentioned in this paper could sovle the problem.
http://www.designers-guide.org/Analysis/
I've read through the paper and think that the method will work. Unfortunately, by now,  I haven't figured out how to save the MonteCarlo simulation results into a file.
Hope some experts  helps us out! By the way, I use spectre to do the MC simulation and use Matlab to do the post-processing.
Thanks in advance.
« Last Edit: Dec 3rd, 2009, 6:03am by BackerShu »
Dipankar
Reply #2 - Dec 3rd, 2009, 6:52am
BackerShu wrote on Dec 3rd, 2009, 4:20am:
Thanks in advance.
Hi ,
      There is one tool out there - SOLIDO VARIATION DESIGNER. Itegrated with Virtuoso, can work with HSPICE  netlist too. They basically hack your simulator engine to run your desired MC simulation/ corner simulation. What is extra is all kind of post processing, backannotation of any particular result to ADE, sensitivity analysis and so on.
With Thanks and Regards,
Dipankar.
