Sep 28th, 2024, 12:18pm
questions about amplifier DC biasing (Read 6664 times)
LeonQQ
LA
Oct 29th, 2009, 6:42pm
Hello folks,
I wonder in real chip testing, how do people set up the DC biasing to the OTA input nodes Vin+ and Vin- as shown in the figure below.
The pseudoresistors Mb1 -Mb4 provide very high resistance (~ 10G ohm) thus making the nodes Vin+ and Vin- almost floating in reality.
Thank you all.
Leon
[img][/img]
Mayank
Re: questions about amplifier DC biasing
Reply #1 - Oct 29th, 2009, 10:28pm
Hi Leon,
             The i/p nodes of an OTA are generally set by the o/p CM level, in most of the cases i/p CM being equal to o/p CM...The -ve terminal is biased by the o/p node through Mb1 & Mb2 ....On the +ve node, the OTA i/p is biased through the branch Mb3-Mb4 from vdd/2
High Resistances (~ 10G as you said) ensure that your AC signal doesnt cross them. On the other hand, for DC current, since there is no DC current flow allowed at i/p node because of i/p caps...The i/p node settles to the voltage on the other end of the High-Resistance, since the drop across the resistor is ZERO.....
regards,
Mayank.
LeonQQ
LA
Reply #2 - Oct 30th, 2009, 9:21am
Thank you Mayank. In the lab testing, when I change the DC at Vref node, the OTA output wave changed drastically. It looked to me that the DC at Vin+ node was disturbed by the DC change at Vref node. But How come the DC change coupled through the cap? Maybe I changed the DC too quickly, then it changed the charge at Vin+ node through charge injection. But the problem is that the DC at Vin+ and Vin- seemed not being able to settle to Vdd/2 correctly.
Mayank
Reply #3 - Oct 30th, 2009, 3:00pm
Hi Leon,
             Answer to your question : Yes, if you change your DC level too quickly, it will couple and you will see a charge-sharing/feedthrough...It's categorized as a Fast transient effect...As for your query that Vin+ and Vin- are not pinning at Vdd/2,  ----->
1.    First of all, are you using an OTA or an opamp ? i hope you didnt mistakenly write OTA instead of opamp....
2.    In an opamp, o/p CM voltage is always of a concern in analog ckts, since it biases the next stage...So you have a CMFB Loop to control the O/p CM level....There you can use this o/p CM Level to bias the input at a fixed CM level, common for both i/p and o/p(set by CMFB Loop)
      On the Other Hand, In you OTA, If you have a well defined CM level(a single-ended implementation or a CMFB control in a differential one), then you can use o/p to bias i/p through a high-resistance path Mb1-2, OTHERWISE both Vin- and o/p will settle at the o/p CM level generated(which you cant be certain that it's vdd/2)
regards,
Mayank.
LeonQQ
LA
Reply #4 - Oct 30th, 2009, 3:31pm
Thank you Mayank for your help. I use a single-ended OTA (high impedance output node).
ic_engr
Reply #5 - Nov 2nd, 2009, 11:28am
I guess the goal is to have a very low High Pass corner using this large resistor. Note that the resistor is signal dependent. What happens if the signal at the o/p of the opamp is close to rail-rail, the MOS transistors channel resistance woudl surely reduce and the output signal may dsitort. How would this be handled ? Any ideas or suggestions.
ic_engr
LeonQQ
LA
Reply #6 - Nov 2nd, 2009, 1:18pm
Hello Ic-engr, you are right, when the output swing goes high, the pseudo-resistor value goes down, this is one of the disadvantages of this circuit
Mayank
Reply #7 - Nov 2nd, 2009, 9:13pm
Hello Leon & ic-engr,
                               The effect you are pointing out is inevitable if you use these kind of psuedo-resistors...Why dont you guys use poly-Si resistors instead of diode-connected devices...Because of these effects, esp. in filters where linerarity is a concern, we use poly resistors. Also, you can try triode-biased devices...Maybe that will help..
There are many ways to implement a high Resistor value....Most feasible being Swithed-Cap implementation....What say ?
--Mayank.
LeonQQ
LA
Reply #8 - Nov 2nd, 2009, 10:55pm
Hello Mayank, it depends on applications, I used this amplifier for bio-medical purpose, I need a high-pass pole around less than 1 Hz to reject DC offset introduced by electrode-tissue interface. The triod-biased MOS need a well controlled gate bias which can be costly to generate on chip. Switch-cap need clocks and also not suitable for this extremely low-noise application.
Besides, I found it was actually the on-board buffer and oscilloscope probe causing the measurement problem. DC bias is ok.
But since I am trying to probe the high-impedance output node, I buffered it through an discrete buffer, but the buffer itself introduced a lot of noise and distortion, since my input is in the mV range.
Is there a good way to probe a high-impedance node without buffer it on board?
Thank you
Mayank
Reply #9 - Nov 3rd, 2009, 12:07am
Hi Leon,
               You want to probe a high-impedance node...& want DC signals to be filtered...In short, you need a high-pass with wery low cut-off as you said earlier....Try a L-C high pass filter...You can use active-inductors if you want.....+ it can be on-chip...what say ??
vivkr
Reply #10 - Nov 3rd, 2009, 2:38am
LeonQQ wrote on Nov 2nd, 2009, 10:55pm:
Thank you
Hi Leon,
I would say No! there is no good way to probe a high-impedance node without a buffer. As a matter of fact, the chances of ruining performance are very high if you take out a high-Z node off-chip for direct probing.
So the buffer solution is fine as long as you are not trying to see the input DC level with a high accuracy. I would try only to see the DC level there, and be aware that the buffer introduces some error too. It would be difficult to verify the < 1 Hz cutoff at input by direct probing. However, you should see the characteristic when you probe your amplifier output. So I see no real reason for direct probing of the input.
As for the rest, what you are doing is quite a standard practice.
Vivek
LeonQQ
LA
Reply #11 - Nov 3rd, 2009, 4:36pm
Thank you Vivkr, I am searching for some low-noise low-voltage discrete commercial opamp as my buffer.
