Jul 16th, 2024, 7:11pm
Mismatch parameters (Read 2197 times)
raja.cedt
Mismatch parameters
Nov 12th, 2009, 9:42pm
hi,
   how to get Ab and Avt for any process node (can i find any where in the process file), so that i can estimate roughly whats the mean variation.
rajasekhar.
Mooraka
Lexington, KY
Re: Mismatch parameters
Reply #1 - Nov 13th, 2009, 8:54pm
I think usually the foundry process guys specify the Pelgrom coefficients for each device type in the EDR document or individual device model release documents.
Ram
Riad KACED
Swindon, UK
Reply #2 - Nov 16th, 2009, 12:30am
Hi Raja,
Yes, you better look at the Electrical Rule Manuals provided by your foundry.
Another way is to look at your Spectre (or Eldo, etc) Model files to see whether these parameters are provided for dcmatch analysis.
If you fail to get them from any of the above, then you would be able to extract those parameters from MC simulations. I would advise asking your foundry though.
Cheers,
Riad.
Riad KACED
PDK, EDA Support Engineer.
