Jul 16th, 2024, 7:33pm
how to reduce the 60 Hz power line ripples (Read 2945 times)
LeonQQ
LA
Nov 14th, 2009, 1:49pm
Hi All,
I wonder how to reduce the 60 Hz power line ripples in real measurement?
I grounded the inputs of my amplifier, but the output shown on the oscilloscope had a big ripple (around 30 mVpp) mainly 60 Hz freq component. I probed a high-impedance node through a discrete buffer, the buffer output impedance is low (tens of ohms), the oscilloscope input impedance is 1 Mohm.
Through all corner simulations my PSRR is not bad at 60 Hz (> 80 dB), and usually op amp PSRR is better at low freq than higher freq.
I wonder where usually these 60 Hz ripples would coupled in, from the discrete buffer? I am not sure.
Thank you for the help.
Leon
Re: how to reduce the 60 Hz power line ripples
Reply #1 - Nov 14th, 2009, 10:44pm
(1) Observe DC Power Supplier Output by Oscilloscope without connecting DUT.
Is there no 60Hz ripple ?
(2) Confirm AC Ground of DC Power Supplier and Oscilloscope.
How do you feed AC power to these equipments ?
(3) Turn off every lights in the room.
(4) Use battery instead of DC Power Supplier
Condition of AC power feeding and Ground including DUT is very suspicious.
« Last Edit: Nov 15th, 2009, 1:59am by pancho_hideboo »
