Jun 1st, 2023, 3:33pm
A-Weighting VerilogA Model (Read 8840 times)
keplin
SF Bay Area
Nov 20th, 2009, 12:38pm
Does anyone out there have an A-Weighting filter model in VerilogA?
View Profile keplin keplinjohansen   IP Logged
Re: A-Weighting VerilogA Model
Reply #1 - Nov 20th, 2009, 11:58pm
keplin wrote on Nov 20th, 2009, 12:38pm:
What do you mean by "A-Weighting filter" ?
Is it "Moving Average Filter" ?
Reply #2 - Nov 21st, 2009, 8:10am
Pancho,
  A-weighting is a spectral mask for sound pressure from the IEC.
Basically, the limitations of human sensitivity to sound can be used
in calculation of a audio converters "goodness", for example, SINAD.
Keplin,
  Do you need a Verilog-A model? I thought that A-weighting could
be treated like filtering, that is, just multiplying the frequency
domain response. So the A-weighting can just be done during
post-processing, in Calculator.
Reply #3 - Nov 21st, 2009, 8:40am
sheldon wrote on Nov 21st, 2009, 8:10am:
Sheldon, thanks for information.
Expression as s-domain transfer function of A-weighting filter is described in the following.
So you can easily implement it as Verilog-A module.
http://en.wikipedia.org/wiki/A-weighting
keplin
SF Bay Area
Reply #4 - Nov 24th, 2009, 4:19pm
Sheldon,
  Yes I could do it in the calculator, but I would rather simulate with a Verilog-A model so that I can analyze the simulation output directly.
  I am not very savvy at Verilog-A and am just trying to save time converting the s-domain model to a time domain model for Verilog-A by seeing if anyone out there has something already implemented.
  Keplin
Reply #5 - Jan 5th, 2010, 12:22pm
It should be relatively easy to take the s-domain transfer function on the wikipedia page that Pancho referenced, multiply out the denominator and then use the laplace_nd function in VerilogA to represent it.
I'll leave that as an exercise for you (assuming you've not already done it!)
