Aug 17th, 2024, 7:14am
Is the SNR/DR spec reasonable? (Read 468 times)
xuedashun
Nov 20th, 2009, 1:55pm
In a class D amplifier
2 stage sigma delta modulator + driver + speaker
the input is analog signal
the spec is: SNR/DR min=85dB, -60dBFS
From my understanding, it's impossible for 2stage SDM to reach 80dB
SNR. If the SMD is used in classD, is the 85dB spec reasonable?, if
reasonable, why??
Thanks.
vivkr
Re: Is the SNR/DR spec reasonable?
Reply #1 - Dec 11th, 2009, 5:59am
xuedashun wrote on Nov 20th, 2009, 1:55pm:
reasonable, why??
Thanks.
I think that would depend on the OSR. As a matter of fact, the first SDM I ever designed had an ideal SQNR of around 84 dB, and was second order if I recall correctly. Of course, the real SNR was a few dB lower as it was limited by thermal noise.
Vivek
