Pilo,
Since the op-amps are ideal, they probably are not causing the problem:
1) Are the capacitors linear capacitors or are they device capacitors? If the device capacitors are model as non-linear devices, then the you might try replacing them with linear capacitors. If the distortion improves, then the issue is the device capacitor non-linearity.
2) Switch test 1: You might try replacing the capacitors with the switch from bmslib. sw_no. This will allow you to see if the issues is the switches. If the distortion improves then the issue maybe that the switch on- resistance needs to be more linear across the voltage level.
3) Switch test 2: Use the bmslib switches and lower the on-resistance, if the distortion improves, then there maybe a settling issue, the switch R X Capacitor RC time constant is too long for the time allowed to settle. Or incomplete settling is the source of the distortion.
4) You might also want to verify your assumption that the op-amps are ideal. If the op-amp models are not ideal then there are other issues that need to be explored.
5) BTW, you have not provided much detail so my assumption is that you are designing an audio SD expecting ~90-96 dB of SINAD are seeing ~70-80dB due to large distortion tones. That is basically you are close to your expected results with more distortion than expected. In addition, the other assumption is that structure is fully balanced, timing is correct, and the op-amps have high CMRR so that the effect of charge injection, ... can be neglected.
This is nice place to use behavioral modeling to help you isolate the issue.
