ic_engr wrote on Dec 16th, 2009, 8:54am:I am looking for smaller footprint for 100nF and lower capacitors.
What do you mean ?
You mean "Low-Profile" ?
ic_engr wrote on Dec 16th, 2009, 8:54am:No. I meant 0201. Currently you can get in 0201 capacitors upto 100nF.
You mean 0.2mm x 0.1mm ?
I don't know such size.
Again see
http://www.yuden.co.jp/us/product/goods_top/goods_top1.htmlMaybe you mean "EIA" code. However I mean "JIS" code.
JIS "0603" is equivalent to EIA "0201".
JIS "0402" is equivalent to EIA "01005".
JIS "0603" is 0.6mm x 0.3mm
JIS "0402" is 0.4mm x 0.2mm
As mass products,
You can get 0.01uF=10nF for JIS "0402" size.
You can get 0.47uF=470nF for JIS "0603" size.
As engineering sample, you can get 1uF=1000nF for JIS "0603" size.
http://www.yuden.co.jp/us/release/pdf/pdf_117.pdf
