Aug 16th, 2024, 7:14pm
comparaor in SAR ADC (Read 2074 times)
duncandu
Dec 19th, 2009, 9:14pm
I'm currently working on a SAR-ADC based on charge-distribution scheme, and I would like to know if the input capacitor of the comparator will affect the INL and DNL of the ADC?
For example, if my LSB cap is ~30fF, it seems that the input capacitor of comparator should be much less than 30fF. However, in order to increase the gain/resolution of comparator, we usually choose large input transistors. How to solve this problem? Or, in fact, do I misunderstand the effects of the input capacitor?
Thanks very much.
~Ken
vivkr
Re:  comparaor in SAR ADC
Reply #1 - Jan 4th, 2010, 2:05am
Typically, the input cap should only induce an attenuation. Since the operation of a classical SAR requires the comparator to merely detect the sign of the input, this should not affect INL/DNL. If your comparator is not well-designed, then you may have troubles due to kickback coupling through to the input though.
Vivek
