Aug 16th, 2024, 3:16am
how to minimize the bias circuit's effect to LC VCO's phase noise (Read 6005 times)
anny
Dec 20th, 2009, 5:57am
hi all,
I need design a 1.4GHz VCO using 0.13um CMOS process. I find that with ideal tail current, the larger current the phase noise is better, however, when I add the current bias circuit, phase noise degenerate much. how to optimize the current? how the bias current affect the VCO's phase noise?
thanks!
raja.cedt
Re: how to minimize the bias circuit's effect to LC VCO's phase noise
Reply #1 - Dec 21st, 2009, 5:46am
hi,
  can you post the schematic..is it LC vco or ring?
rajasekhar.
wave
Reply #2 - Dec 22nd, 2009, 1:52pm
Your phase noise analysis is picking up the Bias circuitry.  That is a real issue.  You may need to re-design the bias for lower noises (1/f, thermal).  The max I should maximize the oscillator amplitude, no more.  You are trapped between maximizing signal and minimizing noise
--- at the moment it seems like adding current adds more noise than signal, which means your bias is the limiting factor.
Cool
raja.cedt
Reply #3 - Dec 22nd, 2009, 8:26pm
hi anny,
           as wave said bias  noise has lot of impact on overal phase noise,even though it's magnitude is less due AM to PM conversion and 1/f up conversion you will end up with huge amount of PN. you can refere the following papa to get some idea.
'The Impact of Device Type and Sizing on Phase Noise Mechanisms'
Rajasekhar.
Reply #4 - Dec 26th, 2009, 4:10pm
run a noise analysis on the bias circuits and find out what the sources are. In a similar manner to how you would on a reciever signal processing chain.
Adjust geometries/current accordingly.
As a start point, put an ideal voltage source controlling the bias of the current source. If you can't get teh current source (minus all the bias control circuits) quiet enough, you need to rethink the architecture.
Also - sometimes you can reduce the BW of the noise by passive methods, (filter the bias) and suppress the low frequewncy part by feedback methods.
lots of possible options
Mayank
Reply #5 - Dec 27th, 2009, 5:48am
Hi
@ Anny :
            I agree with Jerry's suggestion on passive filtering. I have also used it to reduce Noise BW...
@ Jerry :  can you pls. elaborate a bit more on Quote:
suppress the low frequency part by feedback methods.
 Can you suggest some references on this kinda noise suppression by feedback in bias ckts. ??
& btw, hope u had a Merry Christmas !! Smiley
thanx,
Mayank.
RFrequency
Singapore
Reply #6 - Dec 30th, 2009, 9:22am
A filtering technique to lower LC oscillator phase noise, JSSC, from Abidi. This paper is the most famous one for noise filtering.
Mayank wrote on Dec 27th, 2009, 5:48am:
Hi
@ Anny :
thanx,
Mayank.
rfcooltools.com
Reply #7 - Jan 2nd, 2010, 11:50pm
If your bias is broadband ie contributes noticeable noise at 1xLO and 2xLO etc then these noise sources will either feed through or be harmonically converted.  Then in this case filtering of the bias will help,  additionally you may externally regulate (external since cap on chip usually is prohibitively large), you may be able to knock down the 0XLO related noise or atleast push them low enough to be reduced by the PLL loop.
Also,
Consider a differential GM type of oscillator, a considerable amount of noise can be attributed to 2xLO and other even order harmonic mixing at the common source.  This often gets worse when the current increases due to the impedence being lowered at the common source.  This is commonly eliminated by adding a resistor or some frequency selective high impedance circuit such as a LC tank.
Finally,
VCO phase noise improves when the voltage of the oscilation increases and not only the current increases, If you increase the current and the amplitude of the oscilation only slightly increases then phase can be worse not better.
