Aug 16th, 2024, 1:19am
Quadrature VCO OR Quadrature Divider ? (Read 1121 times)
Mayank
Dec 30th, 2009, 10:19pm
HI all,
If i want Quadrature I-Q LO signals, There are two major ways :--
1.  Single Phase VCO -- running at 2 * FLO + a Quadrature Divider.
2.  Quadrature VCO -- running at FLO
Which one's better ??
thanx,
Mayank.
Re: Quadrature VCO OR Quadrature Divider ?
Reply #1 - Dec 31st, 2009, 2:17pm
you can generally get better duty cycle and lower phase noise out of the 2X VCO and digital (ECL arcitecture) type divider.
rfcooltools.com
Reply #2 - Jan 2nd, 2010, 11:17pm
I have always talked my self out of Quadrature VCO's on a IC when it comes to making an LO signal for Quadrature conversion here is why:
Open loop phase noise is worse since the VCO A will present Noise to VCO B at the most sensitive transitions of each others duty cycle.
Closed loop phase noise will be worse since ulimately the LO from only one VCO will operate the PLL phase detector.  That VCO will get the normal loop suppression of noise, but since the other VCO tune voltage would be tied to the same point its noise will not be suppressed by the loop unless it is common to both and worse yet the VCO not operating the phase detector will get the noise of the one operating the detector added to it since it is uncorrelated.  There may be a way using two PLL's, but Getting the Quadrature correct is not obvious.
EM Coupling: depending how close the coils are to each other the coupling of these coils and the phase angle the resulting transformer will present the equivalent of an inductor with a different value and potentially lower Q than intended and when combined with the PLL loop the satisfactory locked condition may be where the phase is not 90 degrees.
On chip inductors Q increases with frequency while the degradation of varactor Q is negligible at frequencies of say 3 to 4GHz when compared to other deQ'ing elements.
Higher frequency inductors are typically smaller in value and thus in physical size thus cheaper.
Almost always the divided frequency equivalent phase noise will be better both in current, area, and simplicity which is usually always a win win.
Mayank
Reply #3 - Jan 4th, 2010, 12:12am
thanx Jerry and rfcooltools,
                                    your replies helped a lot. I also studied further on this topic & i also think Q-vco is not such a good idea as a Q-divider with a single-phase VCO.
thanx,
Mayank.
raja.cedt
Reply #4 - Jan 4th, 2010, 3:57am
hi,
  apart from the disadvantages explained above, both vco's will not  oscilate where Q will be maximum due to coupling Transistors current.
Rajasekhar.
Mayank
Reply #5 - Jan 4th, 2010, 5:37am
Hey raja,
              Didnt understand your last post so much....Can you pls. explain in some further detail ??
Mayank.
Reply #6 - Jan 4th, 2010, 6:18am
Mayank wrote on Dec 30th, 2009, 10:19pm:
Regarding current consumption, "2" is superior than "1".
Regarding phase accuracy, "1" is superior than "2".
Also you should pick up other scheme such as VCO -- running at FLO with passive poly-phase filter and buffer as candidate.
However I don't know actual product which is realized by "2".
