Jul 18th, 2024, 10:09pm
Designing a VDD/2 reference (rail splitter) (Read 8093 times)
AnalogDE
Dec 21st, 2009, 10:55pm
I'm designing a VDD/2 reference that splits a 1.5V supply.  Error needs to be ~1mV or less, and the generator needs to be low impendance.
One way to do it:
I could use a simple resistor divider, but I need switches in series with the divider to turn it off when not in use... These switches will contribute a Resistance->Voltage error... Does anyone know of any schemes to try and cancel the error contribution from the switches?
If anyone can think of any other good schemes, lemme know.
Thanks!
wave
Re: Designing a VDD/2 reference (rail splitter)
Reply #1 - Dec 22nd, 2009, 9:44am
So does this mean your supply is as clean as 2mV, or are you drinking too much egg nog?
You probably need a trimmed BG Reference and a fraction of that.
Cheesy
Wave
AnalogDE
Reply #2 - Dec 22nd, 2009, 10:49am
wave,
Actually the error should be specified from the ideal VDD/2 output -- this reference voltage needs to track the supply.  So it can't be BGV-based.  The error should be small.
AnalogDE
Reply #3 - Jan 7th, 2010, 5:41pm
I've convinced myself that the switch device doesn't make a big deal -- since its resistance is small compared to the ladder it has a negligible effect on the output voltage (vs process and vs temp)
I need very fine steps -- ~2mV range.  With a 1.5V input voltage, that's 1.5V/2mV = 750 segments.  I need the 2mV step size to only correct for variation from the ideal midpoint value, so quantization error is ~1mV max.
In order to cut down on the large number of (small L) segments, is it possible to group into fewer segments near the rails (with larger L) and use the smaller segments around the midpoint to correct for process variation?  I am using poly resistors.
Anything I should watch out for here?
Thanks!
Reply #4 - Jan 8th, 2010, 1:17pm
that is an awful lot of fanciness to get a mid scale voltage.
A thousand odd resistors will eat up a lot of space.
suggest you look at your system and ask why does a mid scale reference need to be so bloody accurate?
eecs4ever
Reply #5 - Feb 24th, 2010, 11:59am
hi,
see attached picture
eecs4ever
Reply #6 - Feb 24th, 2010, 12:07pm
to be able to turn off the R ladder, we need some series switches.
If this VDD/2 node doesnt draw DC power, then we can use a structure shown below.
As long as we make the nmos / pmos resistance small enough compared to the resistor R value. Only 10% matching between the N and P is required.
AnalogDE
Reply #7 - Feb 24th, 2010, 5:54pm
Thanks eecs4ever.
Right now what I have is just a very large NMOS at the bottom of the ladder (without the PMOS in your scheme).  I like your scheme because if the N and P switches are sized to have roughly equal resistance, then the tap point is right at the center, whereas in my scheme I have to compensate for the NMOS IR rise.  Are there any other advantages?
I'm wondering if your scheme suffers from more variation at cross corners (slow P, fast N and vice versa).  I guess this is mitigated by having them quite large.
eecs4ever
Reply #8 - Feb 25th, 2010, 9:17pm
Hi Jiesteve,
I think its fine either way, as long as your resistance is dominated by the resistor R. Keep the mosfets large so that its variation doesn't hurt your accuracy.
One thing to keep in mind is that mosfet do have gate leakage, especially for the thin-oxide devices in the lower technology nodes. When you are trying to lower the ON resistance, its probably you will need a very large transistor. simulate the gate leakage and make sure it doesn't hurt you. Gate leakage tend to have large variations from run to run and varies exponentially with temperature and voltage.
Reply #9 - Feb 26th, 2010, 1:53pm
NMOS and PMOS do not scale together and do not track each other
AnalogDE wrote on Feb 24th, 2010, 5:54pm:
Thanks eecs4ever.
