Thanks a million for replying in sequence. I have attached the paper here in my earlier reply to Raja. My circuit is based on the topology discussed in that paper.
Quote:Place a high Resistance in parallel with C2 across your opamp output and pin Vn so as to provide a DC Feedback.
I thought of this too and actually included this into the circuit. However, as reported in the paper, the feedback resistor was not included by the author. So, I was contemplating if this was a correct move. So, in this case, a feedback resistor is required then?
Quote:I dont see any wire / pin names Vin...Though pin Vn is clearly visible...I assume you are referring to Vn as Vin.
Perhaps, the image I attached was unclear. Vin is a negative input applied to one of the terminals of the resistor. It will be clearer if you look at the circuit in the paper. Sorry about that.
Quote:How much current are you feeding to the F2V converter and how much to the VCO ??
The FVC is implemented as a simple switched capacitor network. Will current be an issue here? Sorry I didnt really check this out. But i will perform a simulation and see. Thanks!
All in all, I need a highly linear VCO to realize a time based ADC where other constituents blocks will come together as well.
Once again, thanks for the help and effort in replying. Please continue to assist me. I will be more than glad to provide more information if required.
Thanks a million
