Jul 18th, 2024, 4:25am
spectre RF simulation (Read 219 times)
hala youssef
Jan 08th, 2010, 6:46am
Where can I write the -E command to use spectreRF simulation to run the ac analysis of switched capacitor circuit?
Re: spectre RF simulation
Reply #1 - Jan 8th, 2010, 9:34am
Presumably you are asking how to apply spectre to Listing 1 of http://www.designers-guide.org/Analysis/sc-filters.pdf. Use ...
spectre -E tah.ckt
hala youssef
Reply #2 - Jan 12th, 2010, 4:11am
I want to know where can I write this command "spectre -E tah.ckt "?
Also, is it mandatory to describe the circuit using verilogA or it is
possible to use schematic view for the circuit description?
Additional information:
I am trying to design SC BPF and I need to make the ac analysis for my
circuit.
Reply #3 - Jan 12th, 2010, 4:29am
hala youssef wrote on Jan 12th, 2010, 4:11am:
Enter as Unix Command.
See http://www.designers-guide.org/Forum/YaBB.pl?num=1192525133/20#20
Also, is it mandatory to describe the circuit using verilogA or it is possible to use schematic view for the circuit description?
It seems you don't understand netlist for simulator.
You have to write Verilog-A block as Verilog-A code.
But for instantiation of it as test bench netlist of spectre with analysis statements and signal source statements, you can do it by either text editor or schematic view.
hala youssef
Reply #4 - Apr 7th, 2010, 11:46am
Sorry, my question was not accurate. My question is how can I use the analog environment in cadence to make the ac analysis of switched capacitor circuit?
smalin
austria
Reply #5 - Apr 9th, 2010, 3:55am
hala youssef wrote on Apr 7th, 2010, 11:46am:
This is how I do it with my BPF:
1. On schematic put voltage source on the input and set PAC magnitude to 1. Do not forget to put clock source.
2. In ADE choose PSS and set parameters
- clock is from shematic - set fundamental to auto calculate
- number of harmonics 0
- tstab to what you need
3. In ADE choose PAC and set parameters:
- PSS beat freq should be set automatically
- start, stop and others like for AC
- maximum side bands 0
Start the simulation.
BR
View Profile smalin_pda   IP Logged
