Jul 2nd, 2025, 11:10am
Input Common Mode in Non-Inverting Amplifier (Read 8922 times)
ic_engr
Jan 12th, 2010, 12:47pm
Hello All,
I am designing a low noise non-inverting ampliifier. The supply voltage is 1.0V. The dc level of input is 0.5V. The application I want to use this amplifier provides inputs having peak-peak of 600mV. How can I design the input stage of the amplifier to handle such a large input signal when my supply is only 1.0V, I am concerned about the input common mode range ?
ic_engr
ACWWong
Oxford, UK
Re: Input Common Mode in Non-Inverting Amplifier
Reply #1 - Jan 12th, 2010, 1:02pm
If the DC common-mode input is fixed at 0.5V you could use either P or N input differential pair, so long as you have enough headroom for the current source.... this depends on your technology (e.g BJT wouldn;t work). Assuming CMOS, low thresholds help.
You can also use parallel N and P input pairs, this is especially required if your common-mode range input is wide. Various techniques exist to keep the gm constant over the common-mode input range required.
A good reference these parallel N & P inputs is:
Shouli Yan and Edgar Sanchez-Sinencio, “Low Voltage Analog Circuit Design Techniques: A Tutorial,” IEICE Transactions on Analog Integrated Circuits and Systems, vol. E00-A, no. 2, February, 2000.
cheers
aw
Mayank
Reply #2 - Jan 12th, 2010, 8:46pm
     Same advice --- Go for a Folded Cascode kinda topology.
   As ACWong says, Rail-to-Rail ICMR can be supported by parallel P & N Differential Input Pair.
  You can go for Constant Gm ckts too if you require a very accurate gain over PVT.
--Mayank
ic_engr
Reply #3 - Jan 13th, 2010, 9:54am
I believe Folded Cascode is NOT practical for 1.0V operation due to headroom limitations. I need a DC OpenLoop Gain of atleast 70dB.
ic_engr
Dipankar
Reply #4 - Jan 13th, 2010, 4:29pm
yes 70 dB will be difficult with 1V supply. But the headrom problem will be more if you go for current-mirror load type.
Which tech node? What's your VT ?
If you need rail to rail ICMR then folded cascode with both p & n type diff pair will be the best candidate. Now for 70 dB gain you can try gain-boosted load.
With Thanks and Regards,
Dipankar.
Mayank
Reply #5 - Jan 14th, 2010, 1:06am
Use Low-Voltage Cascode Biasing & Go for two stage design to achieve  70 dB Gain.
Mayank.
ic_engr
Reply #6 - Jan 14th, 2010, 8:19am
Tech is either 90nm or 65nm, diff pair is SVT all other transistors ar HVT.
ic_engr
Asmodeus
Reply #7 - Jan 18th, 2010, 11:09pm
70dB gain will reflect to a maximum input of less than 1 mV for 1 Volt supply(even neglecting the overdrive voltages). How can u get 70dB gain for 600mV peak to peak input with 1V supply ??
~VJ~
View Profile Asmodeus   IP Logged
ACWWong
Oxford, UK
Reply #8 - Jan 19th, 2010, 5:13am
Asmodeus wrote on Jan 18th, 2010, 11:09pm:
Hi Asmodeus,
The 70dB is for open loop gain. Hence the amplifier can then be used in a feedback configuration (in this case non-inverting) to yield the closed loop gain required. Please remember an ideal op-amp has infinite open loop gain...
cheers
aw
Asmodeus
Reply #9 - Jan 22nd, 2010, 3:50am
Of course ! It wasn't mentioned how much closed loop gain is required ! Anyways A rail to rail opamp with both PMOS and NMOS input will be the solution 4 this problem. I guess max of the guys have suggested d same ! other could be Quasi-floating gate techniques by Ramirez !! I wonder if there are any other solution 4 it ! And don't even think of cascoding ! nothing more than a 5 transistor structure !
~VJ~
