Aug 15th, 2024, 11:30pm
Designing class A RF power amplifier: load pull test (Read 2872 times)
DoYouLinux
Jan 17th, 2010, 11:04pm
I am trying to design a class A PA in SpectreRF. I just would like to know that, in order to do a load-pull simulation, do you need to match the input of the transistor for a driving 50-ohm source before doing the load pull ?
For me, I think this is nonsense because we do not know the width and the bias of the transistor in advance. So I just bias the gate and the drain using ideal bias tee (big L and big C) and doing the load pull.
Do you think this is OK ?
Thank you very much,
DYL
Re: Designing class A RF power amplifier: load pull test
Reply #1 - Jan 18th, 2010, 2:36am
DoYouLinux wrote on Jan 17th, 2010, 11:04pm:
As far as S12 is relatively small, it is OK.
See the followings. In this example, Load-Pull simulation is executed without input matching.
http://edocs.soco.agilent.com/display/ads2009/Load-Pull+Simulations
In Load-Pull Simulation, you have to control different impedance value as load impedance for each harmonics including fundamental.
Assume Zload(n*fin),n=1,2,3,4,5,....., generally you have to set these as different values each other.
However it is not so critical for your case, because your PA is class-A operation.
Also see the followings.
http://www.designers-guide.org/Forum/YaBB.pl?num=1242184095
http://www.designers-guide.org/Forum/YaBB.pl?num=1239997125
« Last Edit: Jan 18th, 2010, 8:32am by pancho_hideboo »
DoYouLinux
Reply #2 - Jan 19th, 2010, 12:54am
Hi Pancho_hidebo,
Thank you very much for your reply and explanation. The information is also very useful to me Smiley
DYL
