raja.cedt wrote on Jan 21st, 2010, 8:05pm:hi,
for 3ma change in the current load how much ripple you can tolerate, this is the small signal o/p res which is equal to 1/(A*Gm)..with this exp people used to find A (of course gm is there from load quesent current)
Rajasekhar.
Hi, Rajasekhar
I really appreciate your kindly help.
I hope that for maximum load to no load condition, the output should be stable (that means dc output).
And I agree with you about the small signal output res. But is that means that to get such a main pole with this kind of compensation method, I need even more cap at the output?
And, for the gain part, could you please tell how many small signal gain and dc gain should I get to meet the requirement of the accuray?
Thanks again.
refugee
