Jul 17th, 2024, 5:22am
Understanding "dB per bin" unit (Read 619 times)
neoflash
Mixed-Signal
Designer
Jan 21st, 2010, 8:00am
In sigma-delta modulator's result showing, I often see units defined as
"dB per bin". Sometimes as "dBFs per bin"
How to understand this unit?
wave
Re: Understanding "dB per bin" unit
Reply #1 - Jan 22nd, 2010, 3:57pm
neoflash wrote on Jan 21st, 2010, 8:00am:
FS - Full Scale.
Critical as some converters may clip or distort with large signals.
http://en.wikipedia.org/wiki/DBFS
Bin is usually related to the DFT used to measure the spectral response.
How many points taken relates to the width of a Frequency Bin.
http://www-inst.eecs.berkeley.edu/~ee247/fa05/lectures/L14_f05.pdf
HdrChopper
Reply #2 - Jan 25th, 2010, 5:02pm
Since in sigma delta modulators you deal with noise (quantization noise in this particular case) it is necessary to talk about spectral densities rather than spectra.
Thus dB/bin is a spectral density unit for the noise processed in the sd modulator, pretty much the same way it is done for "continuous time" noise where the PSD in dB/Hz.
In the dB/bin case, you can think of the amount of noise power in each bin, although you cannot tell how it is distributed "inside a bin". That asks for a higher resolution DFT.
Best
Tosei
Keep it simple
