Aug 15th, 2024, 7:52am
IEEE 802.15.4 standard SNR requirement (Read 2602 times)
aaron_do
Feb 02nd, 2010, 7:48pm
based on
https://mentor.ieee.org/802.15/file/04/15-04-0337-00-004b-802-15-4-multipath.ppt...
it seems we need an SNR of at least 14 dB (including the 9 dB processing gain) for the IEEE 802.15.4 standard, while most papers i've read claim we only need aroud 0 dB (examples below). The difference appears to be that the paper above included delay spread in the channel whereas i'm not sure if the ones below did. Can anybody confirm which requirement is more relavant? I'm inclined to believe 14 dB since its stricter and also delay spread is clearly considered.
W. Kluge, F. Poegel, H. Roller, M. Lange, T. Ferchland, L. Dathe, D. Eggert, “A Fully Integrated 2.4-GHz IEEE 802.15.4-Compliant Transceiver for ZigBeeTM Applications”, IEEE Journal of Solid-State Circuits, vol. 41, issue 12, pp. 2767-2775, Dec, 2006.
M. Camus, B. Butaye, L. Garcia, M. Sié, B. Pellat, T. Parra, “A 5.4 mW/0.07 mm2 2.4 GHz Front end Receiver in 90 nm CMOS for IEEE 802.15.4 WPAN Standard”, IEEE Journal of Solid-State Circuits, vol. 43, no. 6, pp. 1372-1383, June 2008.
thanks,
Aaron
