Jul 18th, 2024, 11:26am
Ring osc start up (Read 4911 times)
jugemu1234
Ring osc start up
Feb 16th, 2010, 5:28pm
Im designing 4 stage ring oscillator. Each delay cell consists of 2 cross-coupled inverters.
It can oscillate in any corners but the time to start oscillation is uncertain. I believe this has annoyed not only me, so can you suggest me to get this oscillate properly on start-up?
Assumption; current starved type ring oscillator, enable signal is on much earlier than current is actually supplied.
HdrChopper
Re: Ring osc start up
Reply #1 - Feb 16th, 2010, 7:10pm
jugemu1234 wrote on Feb 16th, 2010, 5:28pm:
I think the problem is the enable signal is on earlier than the bias current.
You should change the generation of the enabling signal based on the bias current you use for suppling the oscillator.
Best
Tosei
Keep it simple
jugemu1234
Reply #2 - Feb 16th, 2010, 7:22pm
I understand your point. But nonetheless, it does not assure it oscillates right after specific time point, does it? If it becomes like inp=inn=op=on=..., which is so rare but possible, it might to take uncertain time to oscillate.
Berti
Reply #3 - Feb 16th, 2010, 11:48pm
Is this not just a simulation problem? If you have enough gain in your delay stages then oscillation will always start due to noise and mismatch. In simulation however, this is not always the case. Do you use initial conditions to ensure that oscillation starts in simulations?
jugemu1234
Reply #4 - Feb 16th, 2010, 11:56pm
In simulation, yes, I can observe oscillation no mater what. As you pointed out, some fluctuation was amplified.
However, what I think problematic is it depends on something unpredictable, somethign uncertain.  For example, ss process at -40, gain becomes small enough probably.
Therefore, I think its better to have sort of start up to provide the seed of oscillation to ensure it oscillates in certain time.
Reply #5 - Feb 21st, 2010, 2:03pm
If you really want this - do a set of switches that forces one stage inputs to opposite states -
generally its not needed, but if it gives you better feelings about it on power up, go for it.
Mayank
Reply #6 - Jun 3rd, 2010, 6:08am
In some chips at 40nm & below, silicon results showed that oscillation on internal oscillator nodes die down too slowly sometimes.
Hence, I generally do that in all oscillators, but i power down all nodes to GND.
That works too, because cross-coupled inverters force opposite movements on psuedo-differential nodes at power-up.
Mayank.
