Aug 15th, 2024, 3:43am
Pages: 1 2 3
How to plot "input reflection coefficient" in ADS (Read 1965 times)
Re: How to plot "input reflection coefficient" in ADS
Reply #30 - May 29th, 2010, 1:00am
DoYouLinux wrote on May 27th, 2010, 6:43am:
After I repeat the simulation in ADS again, I got correct results.
Have you truely come to be able to understand calculation of "Γin_corrected" in Case-2 without using "stos()" ?
[Case-1]
S_Z01_ZL=stos(S_Z01_Z02, {Z01,Z02}, {Z01,ZL})
S_Z01_ZL(1,1) == Γin=(Zin-conj(Z01))/(Zin+Z01)
[Case-2]
S_Zs_ZL=stos(S_Z01_Z02, {Z01,Z02}, {Zs,ZL})
S_Zs_ZL(1,1) != Γin=(Zin-conj(Z01))/(Zin+Z01)
S_Zs_ZL(1,1) == Γin_corrected=(Zin-conj(Zs))/(Zin+Zs)
« Last Edit: May 29th, 2010, 2:30am by pancho_hideboo »
DoYouLinux
Reply #31 - Jul 24th, 2010, 9:19am
Hi pancho_hideboo,
I tried to evaluate input and output reflection coefficients in several ways, including Case 2 you mentioned. The results I obtained are all the same, as shown in the attached figures. If you have more comments, please post again. Thank you very much for your clear explanations, you are a great sensei.
DYL
DoYouLinux
Reply #32 - Jul 24th, 2010, 9:25am
and the results ...
Pages: 1 2 3
