Jul 17th, 2024, 4:26pm
2nd order passive low pass filter (Read 12882 times)
ultimate
Feb 19th, 2010, 10:35am
hello,
can somebody give me the verilog A code for 2nd order passive rc low pass filter(capacitors c1 c2 and resistor r)..
Re: 2nd order passive low pass filter
Reply #1 - Feb 19th, 2010, 11:14pm
The followings are general notes for you.
- Always describe vendor's name and tool's name which you use.
- Don't do multiple posts which are same content.
- Don't request source code or behavioral model without any efforts.
- There are many simulators which have analyses called as PSS, PAC and Pnoise.
- Describe in detail with using correct terminologies.
- Warnigns are different from Errors.
- ADS is not name of simulator.
- There is no tool which name is Cadence.
- Don't use Direct Plot of Cadence ADE blindly without knowing definition.
- All gains in Direct Plot of Cadence ADE are "right", "true" and "practical" voltage gain.
- Don't mix up Simulation with Post Processing. They are completely different phase.
- MATLAB are different from Simulink.
- Learn measurements using actual instruments. Not "EDA Tool Play
ultimate wrote on Feb 19th, 2010, 10:35am:
If you need physical modeling using R and C, you don't have to use Verilog-A.
And you can never generate complex poles if you use only R and C.
For behavioral modeling not physical modeling, what type of model do you need, bidirectional or unidirectional ?
Do you need input and output impedance ?
Is your requirement enough with signal flow model ?
For example, if we use S-parameter formulation, there are three options at least.
(1) Model expressing only S21.
(2) Model expressing {S11, S21, S22}.
(3) Model expressing {S11, S12, S21, S22}, that is, full model.
(1) and (2) are unidirectional.
(3) is bidirectional.
« Last Edit: Feb 20th, 2010, 2:56am by pancho_hideboo »
Marq Kole
Hmmm. That's
weird...
Eindhoven, The Netherlands
Reply #2 - Mar 2nd, 2010, 6:15am
If you want a model, here it is; for the rest I agree completely with Pancho.
`include "disciplines.vams"
module lpf(in, out, gnd);
 parameter real c1 = 100p from [0:inf);
 parameter real r1 = 10k from [0:inf);
 parameter real c2 = 1p from [0:inf);
 inout in, out, gnd;
 electrical in, out, gnd;
 electrical n1;
 analog begin
   I(n1, gnd) <+ c1 * ddt(V(n1, gnd));
   V(in, n1)  <+ r1 * I(in, n1);
   I(in, gnd) <+ c2 * ddt(V(in, gnd));
   V(in, out) <+ 0;
Reply #3 - Mar 2nd, 2010, 6:47am
Marq Kole wrote on Mar 2nd, 2010, 6:15am:
 analog begin
   V(in, out) <+ 0;
What LPF do you want to realize ?
Don't you have typo for "V(n1, out) <+ 0;"
I think it should be : Quote:
module lpf(in, out, ref);
parameter real r2 = 1k from [0:inf);
inout in, out, ref;
voltage in, out, ref;
electrical n1, n2, n3, n4;
analog begin
  V(n1) <+ V(in, ref);
  V(n1, n2)  <+ r1 * I(n1, n2);
  I(n2) <+ c1 * ddt(V(n2));
  V(n3) <+ V(n2);
  V(n3, n4)  <+ r2 * I(n3, n4);
  I(n4) <+ c2 * ddt(V(n4));
  V(out, ref) <+ V(n4);
This is "Signal Flow Model" for second order RC LPF.
Marq Kole
Hmmm. That's
weird...
Reply #4 - Mar 2nd, 2010, 7:21am
Hi Pancho,
This is not signal flow, this is current input, voltage output, the kind of model you would use in a simple PLL. The input is attached to the charge pump which delivers a current, while the output is connected to the VCO which requires a voltage. If you read the specifications there was a specific request for c1, c2 and r - then I guessed this was kind-of the application needed for this filter which I had laying around anyway.
Cheers,
Marq
Reply #5 - Mar 2nd, 2010, 7:26am
Marq Kole wrote on Mar 2nd, 2010, 7:21am:
I got.
zahrein
Reply #6 - Nov 9th, 2011, 9:32pm
inout in, out, ref;
analog begin
 V(n3) <+ V(n2);
May i know the "ref"  refer to what output from the  p/f detector?
Marq Kole
Hmmm. That's
weird...
Reply #7 - Nov 13th, 2011, 1:27pm
ref = signal ground.
In most applications it will be connected to the vss, gnd, or whatever is your reference signal level.
Cheers,
Marq
zahrein
Reply #8 - Nov 13th, 2011, 5:18pm
i see  thanks  for the info.
