Jul 17th, 2024, 4:18pm
assign vs wire command (Read 1706 times)
newic
Nov 18th, 2011, 1:15am
is there a different to use "assign" command and "wire" command for feedthrough signals??
output out, out_wire;
input in, in_wire
wire out_wire = in_wire;
       vs
assign out = in;
any comment?
will the synthesis tool put buffer in between input & output ports?
