The followings are general notes for you.
- Always describe vendor's name and tool's name which you use.
- Don't do multiple posts which are same content.
Don't request source code or behavioral model without any efforts.
- There are many simulators which have analyses called as PSS, PAC and Pnoise.
- Describe in detail with using correct terminologies.
- Warnigns are different from Errors.
- ADS is not name of simulator.
- There is no tool which name is Cadence.
- Don't use Direct Plot of Cadence ADE blindly without knowing definition.
- All gains in Direct Plot of Cadence ADE are "right", "true" and "practical" voltage gain.
- Don't mix up Simulation with Post Processing. They are completely different phase.
- MATLAB are different from Simulink.
- Learn measurements using actual instruments. Not "EDA Tool Play
ultimate wrote on Feb 19th, 2010, 10:35am:can somebody give me the verilog A code for 2nd order passive rc low pass filter(capacitors c1 c2 and resistor r)..
If you need physical modeling using R and C, you don't have to use Verilog-A.
And you can never generate complex poles if you use only R and C.
For behavioral modeling not physical modeling, what type of model do you need, bidirectional or unidirectional ?
Do you need input and output impedance ?
Is your requirement enough with signal flow model ?
For example, if we use S-parameter formulation, there are three options at least.
(1) Model expressing only S21.
(2) Model expressing {S11, S21, S22}.
(3) Model expressing {S11, S12, S21, S22}, that is, full model.
(1) and (2) are unidirectional.
(3) is bidirectional.
