Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Sep 18
th
, 2024, 11:23am
Home
Help
Search
Login
Register
PM to admin
Design
Analog Design
› Ouestion in symbolism...
Previous topic
Next topic
Ouestion in symbolism... (Read 3718 times)
Turin
Greece
Mar 04
th
, 2010, 6:58am
Simple question...Do the mosfet symbols in the image have the same meaning regarding where the substrate is connected?
Thanks!
IP Logged
Re: Ouestion in symbolism...
Reply #1 -
Mar 4
th
, 2010, 7:06am
It depends on a definition of MOSFET as three terminal model in model file.
See your model file.
But I think body is assumed to be connected to "source" in three terminal model of PMOS generally.
Kita━━━━━━(゚∀゚)━━━━━━ !!!!!
http://www7.plala.or.jp/ungeromeppa/flash/kita.html
http://www.youtube.com/watch?v=mjIxGh55bMM&feature=related
IP Logged
Turin
Greece
Reply #2 -
Mar 4
th
, 2010, 9:53am
There is no model file...This(1rst) is an image from a book which i'm was wondering if is means it is actually connected to the source as it generally the case...
IP Logged
aaron_do
Reply #3 -
Mar 4
th
, 2010, 5:33pm
The one on the left doesn't have the substrate connected yet...
IP Logged
kumar.g
Frankfurt, Germany
Reply #4 -
Mar 5
th
, 2010, 12:29am
If substrate connection is not shown, then it implicitly means that it is connected to source. In your case both the ckts are different
IP Logged
Turin
Greece
Reply #5 -
Mar 7
th
, 2010, 5:52pm
So having a schematic with the first symbolism(with the body pin unconnected) for the pmos and for the nmos where do you assume that the body pin is connected in both cases.
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
- RF Design
»» Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
- Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
