Jul 18th, 2024, 12:25pm
duty ratio (Read 3292 times)
manikandan
duty ratio
Mar 04th, 2010, 10:37am
hi,
i have a pulse that has literally 100% duty ratio..i need a duty ratio of 50..how can i do it..
i have to feed this pulse to input of phase detector..so need 50 duty cycle..
rfcooltools.com
Re: duty ratio
Reply #1 - Mar 5th, 2010, 10:51pm
Phase detectors are usually d-flipflops with a reset. therefore your pulse needs only to be long enough to ensure  flip-flop operates (setup hold) correctly.  50% duty cycle is not important since almost all phase detectors us one edge of the clock.  If this pulse train you have is from a frequency doubler or needs to go into one then that is another issue.
ultimate
Re: duty ratio
Reply #2 - Mar 6th, 2010, 12:38am
hi..
my pulse goes from frequency divider..so duty ratio is important..any idea?
oermens
Re: duty ratio
Reply #3 - Mar 6th, 2010, 10:48am
Re: duty ratio
Reply #4 - Mar 7th, 2010, 12:20pm
PLL and frequency multiplication is the classic way of doing this.
If you have either a high frequency oscillator or can create one there are some digital counter tricks to get what you want:
Count the period of the wave, divide by 2 and use that to create a sort of 50% cycle wave.
Analog techniques -- LPF the signal to the fundamental sinusoid. The amplify back to a square wve.
some ideas
tkhan
Re: duty ratio
Reply #5 - Mar 7th, 2010, 3:46pm
can you use master-slave dff to create 4 phases of 50% duty cycle @ f/2, then XOR 2 phases which are 90deg apart to get 50% duty cycle @ f?
