Jul 18th, 2024, 2:23pm
about the ratio between bias circuit and main LNA circuit (Read 1765 times)
yixiusky
Mar 02nd, 2010, 9:25pm
Hello everyone:
I would like to ask one question about the ratio between bias circuit and main circuit.
I design the LNA.
The bias reference current is 100uA, the main circuit current is 10mA.
There are two choice to decide the ratio (1) 1:100    (2) 1:10: ~ 10:100 use two branch
(a) Which one is better considering about mismatch,...?
(b) And except simple current mirror, is there any method or reference talk about high ratio (1:100) current mirror?
Thank you very much
View Profile yixiusky   IP Logged
rfmagic
Re: about the ratio between bias circuit and main LNA circuit
Reply #1 - Mar 4th, 2010, 12:16am
Hi yixiusky,
In order to reduce mismatch you better use multiplicity of no more than 10. Further more, I use the last transistor of the current mirror (the one that's mirroring the LNA core) as RF transistor with same width and length as the LNA CS transistor ( but different multiplicity). this way you can ensure that the current mirror will follow the LNA CS transistor over PVT variations.
Kob
yixiusky
Reply #2 - Mar 4th, 2010, 1:54am
Hi  Kob
thank you very much , you helped me ^^
